I am trying to get a ATI TV Wonder 650 to even allow a machine to boot properly in a couple of older ASUS PCI/ISA/AGP systems. The card itself WORKS as I had it installed and working OK in a newer DELL based PCI-E/PCI host machine. It was basically just plug and play there.
However when trying trying this card on a older ASUS P2B-F host System or ASUS P3-V133 host system or similar AGP/PCI/ISA host, the system will not even POST.
These are older machines that I was intending to re-purpose for video capture with the TVW 650 PCI, but even when stripping the host systems down to nothing but this card and an ATI/Diamond system video card the system will not even attempt to post or do anything at all - just pure black screen. Removing the TV Wonder card from the PCI buss and machines boot fine as always...
Anyone ran across this before ???
tia.
Results 1 to 17 of 17
nada.. Host system just sits. I do see the keyboard being scanned and front panel indicates HD access for a few seconds. But that's it.
Perhaps there is some feature on the ATI that the older motherboard(s) do not like or support.
Have you checked to see if there is a BIOS update?
Are the motherboards older than the ATI 650? -
Yes there is an obvious issue between the host systems and the card, hence the no POST. These are P3/Celeron systems with enough memory on board but a bit dated.
The TV Wonder card is circa ~2006, the host systems are circa ~1999-2001, but I would think PCI is PCI. The host systems are up to date (for what it's worth) BIOS/Firmware wise... There is no firmware updateable on the card itself.Last edited by thghgv; 11th Mar 2021 at 21:28.
Well there were different PCI revisions,
Perhaps the card is not backwards compatible, just a guess -
Yup did that before posting the thread... No go. Same result - no POST with the TV wonder installed. Successful POST
when I pull it from the systems... also reset bios's to defaults etc...
As for PCI versioning, I don't see anywhere in the TV Wonder docs where it says it requires a certain version of PCI to operate.
I dunno... I guess these host machines are just too old to to support the TV capture process. -
since you have an ASUS motherboard, try this - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019WFPSA2&l=en-US
go into the the BIOS and find the correct downgrade setting for the PCIe slot. -
Sage advice if there were any PCIe slots on any of these systems. There are none however... As stated earlier, firmwares on all 3 machines are at their peak - none of these systems have had "updates" coded by the OEM's in close to 20 years. They all have the "latest" available. Slot types for any/all these systems is AGP/PCI/ISA.
I know McPoodle had stated that he/she used "an old machine" with win98 and the TV Wonder 600/650 to do captions/video capture. However, from what I am seeing here these TVW 650 cards are extremely finicky about where they are used. The TVW650 card itself I re-verified as good on a newer class machine so it's definitely these 3 systems that simply will NOT comply. The reasoning for the latter I have not yet been able to comprehend...Last edited by thghgv; 12th Mar 2021 at 18:22.
As I recall, the TV Wonder 600 and 650 devices don't have drivers available for Windows 98. They only have drivers available for Windows XP, Vista, and Windows 7. McPoodle actually wrote that he/she used a "TV Wonder PCI" card in a PC running Windows 98. There are several generations of TV Wonder devices that preceded the TV Wonder 600 and TV Wonder 650 models. One is a "TV Wonder PCI" card that dates from 2000. See https://www.anandtech.com/show/473 I suspect that device is what McPoodle used.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
As far as Win98 goes, NONE of the older host systems I have here will even POST with the TV Wonder PCI card installed. So OS choice is basically moot at this point.
The capture card I have here actually is a "TV Wonder PCI", with the number 650 slapped on the end of it. Not "All In Wonder", just "TV Wonder". No idea what the differences are between the two... It does seem very strange to me that all 3 older ASUS host systems I have here would flat reject this card outright.
McPoodle stated in his/her tests that nvidia host system vid cards and these "TV Wonder" cards did not work and play well with each other. Hence my two other attempts at video/caption capture were on higher end systems that BOTH have Nvidia Quadro cards employed for system video. I'm just following through in an attempt to match ATI with ATI to see if that alleviates the garbage caption issue I have had with ALL these devices... -
pci had 3.3v and 5v versions. but the cards had different slots cut in them to prevent them from going into a wrong voltage slot.
will the old machines post with just the ati vid card?
if the machines have more than one pci slot try them all, as they map into different memory areas and one may have a conflict.--
My point was that the AGP/PCI/ISA systems you are trying to use, which date from 2000 or 2001, may simply be too old to use with a card that was released in 2007. Significant changes to motherboards and CPUs occurred in the space of seven years.
There were lots of differences between the original ATI TV Wonder PCI card from 2000 and the ATI TV Wonder 650 PCI card from 2007. The ATI TV Wonder 650 PCI card has both an ATSC tuner and an NTSC tuner plus analog capture ports, while the original ATI TV Wonder PCI card from 2000 with no number attached had one analog tuner, period. If I recall correctly, one could use the ATI TV Wonder 650 PCI card's digital tuner and its analog tuner at the same time for recording TV.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Yes. As stated above the host systems POST fine without the TV WONDER card installed stripped down to just system video.
Yes. Tried all that as well. Most likely, since I don't hear anyone chiming in as having experienced a similar issue, these machines are probably too old for the TV Wonder I guess... -
That's what it's shaping up to look like... Too bad too as these systems all still work great just that they are older tech. So much for trying to re-purpose any of them...
I have a line on a ATI Radeon PCIe system vid card (for like 20$) that is circa about/around the same vintage as the TV Wonder 650. I will throw the Radeon into my higher end test machine (the one with the Quadro FX 4800) and see if ATI system video along with the TV Wonder 650 PCI yields better results as far as caption capture. It's cheap and worth a shot at this point since everything else I have tried up to now to capture consistently clean captions has been a complete and total bust.Last edited by thghgv; 13th Mar 2021 at 18:21.
I have a ATI Radeon HD5670 PCIe that I got for 20$ installed in the test machine. Attempting to get some captures done. Completely accurate display/capture of CCdata ensues SO FAR. Not getting hopes up yet as I had similar results with the Nvidia card and the TV Wonder before for short bits of time. So now the system vid card AND capture card are matched ATI branded. We'll see how long good accurate CC capture lasts...
ATI All-In-Wonder (AIW) 9600 AGP A/V Output Cable / TV Wonder HD600 PCI
By Eagle_FL3D in forum Capturing and VCRReplies: 23Last Post: 23rd Apr 2018, 17:09 -
ATi TV Wonder Pro Pci window 7 x64 driver
By Milardo in forum Capturing and VCRReplies: 10Last Post: 12th Feb 2018, 18:04 -
PCi-e S-Video device for SVHS-C, or riser PCi adapter
By gilporp in forum Capturing and VCRReplies: 5Last Post: 28th Jul 2017, 13:26 -
Are there any mini pc's with PCI or PCI-e feature?
By vhelp in forum ComputerReplies: 12Last Post: 14th Mar 2017, 12:16 -
USB to PCI / PCI-e i/o adapter kits
By vhelp in forum ComputerReplies: 22Last Post: 7th Mar 2017, 07:59
