Hi, I would like to remove audio track, subtitle button etc. from the default progress bar. Please share a list of commands for display bar to be put in mpv.conf.
the OSC is a built-in lua script, you can disable it and replace it, but by default it has few configuration options.
Ok. Can you please suggest a good replacement lua script then? I would like a simple progress bar with no additional controls as I operate them with shortcuts.
I don't have any recommendations.
--no-osc is how you turn it off.
PotPlayer - show progress bar in full screen on Time Jump?
By mistercool in forum Software PlayingReplies: 3Last Post: 27th Feb 2021, 14:34 -
Can FFMPEG show a percentage done or a Progress Bar?
By marcorocchini in forum Newbie / General discussionsReplies: 13Last Post: 19th Jul 2020, 23:14 -
strange behavior of mpv player
By osmium in forum Newbie / General discussionsReplies: 0Last Post: 25th Feb 2020, 12:39 -
VisualSubSync - Video Bar / Audio Bar / Text Bar
By devilcoelhodog in forum SubtitleReplies: 2Last Post: 14th Feb 2018, 23:35 -
MKVToolNix progress bar
By Vigoo in forum EditingReplies: 2Last Post: 20th Aug 2017, 17:48
