I haven't been able to find a straightforward way to do what seems like it should be simple: cleaning out all duplicate frames from a video, leaving an output file entirely free of them with each frame occurring only once. My immediate need is to convert a clip I made using a screen recording program at 24 fps to 23.98 fps (a setting it doesn't have) by eliminating the occasional duplicates that cause stutter then adjusting the frame rate. But I'm asking the question more generally - how do you nix duplicate frames that don't occur in a regular pattern? A method that's flexible with regard to format would be preferable but I'll take anything that works!
Results 1 to 1 of 1
Removing duplicate frames from YouTube 60fps to 23.976 fps
By AndersonJames in forum RestorationReplies: 39Last Post: 5th Aug 2020, 23:47 -
Duplicate frames issue
By tupper in forum Video ConversionReplies: 1Last Post: 18th Dec 2019, 12:04 -
Replace random duplicate frames with black frames (AVISYNTH)
By benzio in forum EditingReplies: 7Last Post: 31st Jan 2018, 17:43 -
Fix duplicate frames on old digicam video
By Homestar in forum RestorationReplies: 13Last Post: 25th Dec 2017, 01:15 -
Remove duplicate frames from 30FPS video
By midts in forum Video ConversionReplies: 7Last Post: 7th Apr 2017, 09:48
