I followed the guides here for burning a dvd to vcd using the nero burner. My panasonic A112 DVD PLAYER plays the cdrw's fine, but when I try to play them on my portable panasonic L50 DVD PLAYER, it can't read it. My L50 plays standard purchased vcds no problem.
HELP! WHAT ABOUT MOVING THE MPEG1 FILE TO ANOTHER DIRECTORY ON THE VCD NERO TEMPLATE?
Results 1 to 11 of 11
Why one hour? Will it blow up if you take to long, or are you just impatient?
didn't you hear? The world is coming to and end in an hour. Dang it, i wish my encode would hurry up.....
well klapp, about the only thing i can tell you, is to burn it without any relaxed iso settings (iso level 1) and burn at a lower speed. Other than that, you should have planned ahead
I know that the Panasonic L-50 doesn't read CD-RWs. I've noticed the L-50 also has problems with the Verbatim 80 minute CDs. I've had to open and close the cover a number of time before it could read it. Any other CD-R that I've used hasn't had any problems being read by the L-50
I guess I'll try all the settings possible. I've been trying to crack this thing for over 4 days.
If you've been trying to get it to work for four days, why did you wait one hour before your trip to post this message? I mean, for important questions like this one, at least give us two hours.
panasonic dvd players wont play cd-rw's max bit rate on my rv-26 is 2520 also svcd wont play on them unless u give them a vcd template...mothballed my old panasonic player because it wont read cd-r's at all
live and learn i guess...i use only cd-r's now...theyre cheap...i go for max quality....and dont care how many it takes to copy a movie.... 8) besides....changing discs i a good potty or snack break! LOL
SOLID ANSWER: .Tivo to .MPG or MOV
By DarkPhoenix77 in forum MacReplies: 24Last Post: 5th Feb 2011, 17:43 -
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 09:38 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 11:58 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 03:54 -
Need someone who has seen Transformers The Movie(animated) to answer Q?
By Denvers Dawgs in forum Off topicReplies: 10Last Post: 27th Jun 2007, 21:42
