For some years I have had a CM Storm Trooper case collecting dust, and taking up space. I have decided it is time to either use it, or lose it. I envision a build using Win 7 on the internal 1TB HDD, and MX Linux on the 2.5” SSD hotswap X-dock. The PC will be mostly for surfing the net, using Photoshop or GIMP, and word processing (Word 2003). That said, I want to make sure it is able to do streaming from putlockers, 123movies, YouTube, etc., without freezing or buffering....and video editing/encoding/burning, in the unlikely event I find anything worth saving to DVD. For this reason I wanted to run the build by this forum.
Currently I'm focused on the i7-4790k CPU, as it has native support for Win 7, and so far as I can tell, looks powerful enough to do anything I would need doing. The latest & greatest CPUs & motherboards all require workarounds to get them to function with Win 7, which I'm not inclined to mess with. As for motherboards, I'm looking into:
MSI Z97 Gaming 5
MSI Z87-GD65 Gaming
MSI Z97-GD65 Gaming
MSI Z97 GuardPro
MSI Z87-G55
MSI Z97A Gaming 6
Asus Maximus VII Hero
Asus Z97-Pro
I chose them because each has minimum 16GB RAM capacity, the most expansion slots and SATA connectors I could find, VGA port, plus decent reviews. If anyone has a preference, or thinks I should look into another one, I welcome suggestions. I have not gotten to the graphics card yet, but I would require it to have Composite RCA connections, or at least component connections (I think composite and component are interchangeable). I already have a Asus Xonar D2/PM/A sound card I hope to use.
Results 1 to 1 of 1
Fresh x264 10-bit vs Ice Lake hevc qsv 10-bit
By sophisticles in forum Video ConversionReplies: 5Last Post: 7th Jan 2021, 17:06 -
10-bit to 8-bit Video File Conversions - the easy (free) way!
By VideoWiz in forum Video ConversionReplies: 10Last Post: 6th Feb 2020, 04:24 -
Win 7 64 home premium oem upgrade anytime to win7 64 professional
By johns0 in forum ComputerReplies: 3Last Post: 13th Jun 2017, 20:05 -
need help getting LSMash working in win 7 home prem 64-bit...[solved]
By vhelp in forum Video ConversionReplies: 3Last Post: 14th Aug 2016, 15:34 -
MPC HC: 32-bit or 64-bit on Windows 7 64-bit
By flashandpan007 in forum Software PlayingReplies: 20Last Post: 22nd Jul 2016, 10:22
