Some of my .mkv files play well using my Micca but others won't play. This is information of 1 file that won't play. Can you tell me what the problem is and if there's anything I can do to get them to play on the Micca? Further down is a link to information about the Micca.
General
Complete name Not Important (1080p x265 10bit).mkv
Format : Matroska
File size : 539 MiB
Duration : 45mn 29s
Overall bit rate : 1656 Kbps
Encoded date : UTC 2018-08-23 21:17:46
Writing application : mkvmerge v24.0.0 ('Beyond The Pale') 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Video
Format : V_MPEGH/ISO/HEVC
Codec ID : V_MPEGH/ISO/HEVC
Duration : 45mn 27s
Width : 1456 pixels
Height : 1072 pixels
Display aspect ratio : 4/3
Frame rate : 23.976 fps
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : Yes
Format settings, PS : No
Codec ID : A_AAC
Duration : 45mn 29s
Channel(s) : 8 channels
Channel positions : Front: L C R, Middle: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 16 bits
Text #1
Format : S_HDMV/PGS
Codec ID : S_HDMV/PGS
Title : SDH
Text #2
Format : S_HDMV/PGS
Language : Japanese
Text #3
Format : S_HDMV/PGS
Language : Dutch
Text #4
Format : S_HDMV/PGS
Language : Norwegian Bokmal
Text #5
Format : S_HDMV/PGS
Language : Finnish
Text #6
Format : S_HDMV/PGS
Language : Swedish
Text #7
Format : S_HDMV/PGS
Language : Danish
Text #8
Format : S_HDMV/PGS
Language : German
Text #9
Format : S_HDMV/PGS
Language : Spanish
Text #10
Format : S_HDMV/PGS
Language : French
Text #11
Format : S_HDMV/PGS
Language : Italian
Chapters
Language : English
1 : 00:00:00.000 Chapter 1
2 : 00:04:44.034 Chapter 2
3 : 00:12:27.538 Chapter 3
4 : 00:20:08.332 Chapter 4
5 : 00:28:42.220 Chapter 5
6 : 00:37:29.914 Chapter 6
7 : 00:44:37.300 Chapter 7
https://www.miccatron.com/micca-mplay-hd-wlan-1080p-digital-media-player/
Thanks in advance.
Micca has no HEVC (h.265) support? Can I convert them? If so, what program would be good to do that? If not, do you know of a device that I can connect to my tv so that they will play?
The web page you linked to doesn't list HEVC as a supported codec.
And your file appears to be 10bit not 8bit, another problem for players of that generation.Video Codecs – H.264/AVC, MPEG1/2/4, VC-1
You can convert the video to h.264/AVC with programs like Handbrake, VidCoder, AviDemux, ffmpeg, etc.
If your videos are accessible via WiFi (eg, Windows share or NAS) I highly recommend the latest Chromecast with Google TV for about US$50. There's a US$20 Ethernet adapter if your LAN is wired-only. It's a tougher decision if you want to play off a USB drive (flash or hard). The Chromecast only has one USB-C connection and it's used to power the device. To connect a USB drive you have to get a USB-C hub with PD (power delivery) and a beefier power adapter. Adding all that brings the price closer to US$100.
https://www.youtube.com/watch?v=7sb9-NOxZlg
https://www.youtube.com/watch?v=1sCmzFU0nzk
https://www.youtube.com/watch?v=uwSRep-mUP8
The one thing it is missing is AV1 codec support. That will probably be used more and more over the next several years as it's patent/royalty free and compresses better than HEVC. -
Thanks for the information and the links. I'll give them a try and I'll let you know how I do. I can play the files on my desktop but I'd rather watch them on my tv.
Problems Playing MKV Files
By chang123 in forum Software PlayingReplies: 2Last Post: 13th Oct 2019, 01:20 -
Playing MKV files on SmartTV
By ouroboruss in forum Newbie / General discussionsReplies: 5Last Post: 8th Feb 2018, 15:45 -
Problem extracting Audio Tracks from MKV files
By RandomNewbe in forum Newbie / General discussionsReplies: 6Last Post: 19th Jul 2016, 03:30 -
Is there a codec that will allow the playing of mkv files in Windows 10?
By RBCC in forum Software PlayingReplies: 2Last Post: 16th Apr 2016, 15:47 -
Problem playing mts files edited with Avidemux on Panasonic Viera
By AVFun in forum DVB / IPTVReplies: 6Last Post: 20th Mar 2016, 01:29
