Hi,
I've created an XVCD with Nero 5.5 using MPEG2 video.
It seems OK on the PC (RealMagic Hollywood Plus), but my Sony DVP-S725D player does not play the sound and the picture is filled with green and purple stripes.
I used the Dazzle DVC II with the lowest possible bit rate (2MBit/sec) and I tried several resolution. Nothing changed.
Then I decreased the bit rate with TMPGEnc 12g but everithing get worse. The audio was out of sync on the PC and still nohing changed with the stand alone player.
If I use MPEG1 I can go up 2.5 MBit/sec without any problem.
Perhaps the Sony player does not like the MPEG2 on XVCD.
Any idea ?
Thanks,
Cornelius
Results 1 to 1 of 1
Converting video to MPEG2 for Sony Bravia TV
By Teufelshunde in forum Video ConversionReplies: 7Last Post: 6th Jan 2011, 10:39 -
Software Order and use. Edit Sony Camcorder mpeg2 video.
By gerritv in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2009, 02:12 -
Sony M2TS to Mpeg2 on La Cie Hardrive cannot play ?
By WARRANLAMB in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 14th Oct 2009, 04:48 -
Date/time info in video from Sony HD MPEG2 camcorder
By huykin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 27th Jul 2009, 13:50 -
Data Code from MPEG2 Sony file
By provehighman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 3rd Apr 2009, 06:55
