Here is the situation, I have a blu-ray machinery training video that has the typical introductory segments i.e. title, business name etc. One of those segments has an introductory segment that shows foreign language text with no sound. I found the m2ts clip that contains this text and just want to know what free software will allow you to take this m2ts file and edit out the text to make it blank. The video segment is about 20 seconds long. I don't think it needs to be remuxed, as the edited clip will still be there in the stream folder.
TIA
Maczones![]()
You could try to replace the file with an empty dummy file with the sane name and extention.
Thanks that's a good thought. What is the best way software wise to create a m2ts dummy file?
create a new text file and rename it as you like. The extention has to be .m2ts
Cannot insert the video clip creation date on video output.
By ohuser in forum EditingReplies: 4Last Post: 6th Jan 2021, 02:38 -
MOV Files Blank in Picasa, Blank Icons in Win Explorer
By Alwyn in forum Software PlayingReplies: 0Last Post: 8th Dec 2020, 00:58 -
video editor that takes fewest steps to clip video
By easytools in forum Newbie / General discussionsReplies: 16Last Post: 14th Nov 2020, 16:11 -
how do i go from m2ts to a m2ts with a lower bitrate
By BabyDaddy in forum Video ConversionReplies: 12Last Post: 6th May 2020, 20:39 -
Program to cut M2TS file into clip with all tracks "un-touched"
By kpic in forum EditingReplies: 2Last Post: 12th Dec 2018, 13:20
