  1. I left my sd card in the camcorder and forgot about it now the camcorder says No Card and NO Data I have tried a new card but same thing have I got a faulty card receiver
    All it says when I insert the card is No card and no data is my camcorder ruined
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Which camera? (Manufacturer, model number. It might help someone recognize what may be wrong with the camera, if anything.)
    Does the original SD card read correctly in a different device (especially a computer)?
    Check your camera's manual - for the new card, see if the camera requires SD cards to be formatted a certain way before it can read or use them. Or whether or not it has problems or refuses to recognize certain types of SD card (like the higher-capacity cards, for example. Some devices may have problems with SDHC cards.)
  3. Member Cornucopia's Avatar
    Put a brand new, known-good brand blank on in the camera and format it using the camera's firmware. If it still shows nothing the cam is borked.
