I am using a program called FlowFrames to do AI fps interpolation. However I have an issue for when I try and do it with DVD rips. I have attached a picture which helps explain this. Basically, when I input the video, it looks like Number 1 on the picture, but when it comes out, it looks like Number 2. Both times it has the same resolution (720 by 576) which I don't understand, how can the resolution be the same if the aspect ratio isn't?
Does anybody know how to stop this happening?
	No, the resolution is not the same as the aspect ratio. All PAL DVDs use a 720x576 frame (a 5:4 ratio) whether they are 4:3 or 16:9 display aspect ratio. Just tell the program your video is 16:9 DAR or 64:45 SAR (sample aspect ratio). Or tell it to change the frame size from 720x576 to 1024x576.
	Will that not affect the image quality though?
 Is there any way to hard encode that in the video, as I don't want to have to faf about with stretching and cropping options every time I want to play a file, this issue doesn't happen with some video programs, I have no idea why it does with FlowFrames.
	Remux your file with mkxtoolnix if mkv or clever Ffmpeg-GUI for mp4 and set the aspect ratio as you wish (16:9 or 4:3)
  MKVToolnix - changing Aspect RatioBy pooksahib in forum Video ConversionReplies: 4Last Post: 8th May 2019, 07:48
  Changing aspect ratioBy carlmart in forum Video ConversionReplies: 3Last Post: 2nd Oct 2017, 15:48
  Changing Aspect ratio for Online videosBy alan in forum Newbie / General discussionsReplies: 6Last Post: 22nd Feb 2017, 12:59
  Changing aspect ratioBy lucas 1 in forum Authoring (Blu-ray)Replies: 0Last Post: 15th Sep 2016, 10:40
  Need help changing aspect ratio with Handbrake 10.0.6534By jh443 in forum Video ConversionReplies: 2Last Post: 22nd Apr 2016, 02:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
