Hi. I've been able to download video files from TFC.tv using ismdownloader Youtube-DL doesn't seem to work anymore on the site.
The problem is the videos seem to be scrambled when I view them. I've tried to use the Widevine Key and ID that I have found (mind you there's only one Key and ID for both audio and video it seems) and decrypt it using MP4Decrypt but it doesn't seem to be working.
Any thoughts or guidance?
A link to an example show I'm trying to get using a free account
https://tfc.tv/episode/details/214126/la-vida-lena-november-14-2020
Results 1 to 12 of 12
your procedure seems correct. if decrypt no work (if you see scrambled video) maybe you don't have copied correct key.
anyway on your video example posted above not have drm, then don't need key (and not have key!).
download is forbidden, but this is secondary problem. -
i repeat: on this video https://tfc.tv/episode/details/214126/la-vida-lena-november-14-2020
don't need to have key. not have DRM. simply download and play. -
Thanks. Then I must be doing something wrong with the download part maybe?
May I ask, how are you downloading it? What tool are you using and how do you get the specific link to download the video?
Here is another example link that seems to be encrypted too. If this isn't encrypted on your end then it must be my download method.
https://tfc.tv/show/details/6039/miss-grannyLast edited by TekeOnMe; 5th Mar 2021 at 14:40.
The first one as lomero pointed out is not encrypted and you can download it many ways probably, I find the Video DownloadHelper add-on (with installed compainon app for it) to be the easiest.
Oh, I see what the problem is. When one is not logged in, it only gives 2 minutes of the video (unencrypted and can be downloaded).
Probably when you are logged in you can watch the full episode and maybe there's encryption then.
As for the 2nd link, need login info so I can check. -
That might be where the misunderstanding is.
Here is a free movie that comes with a free account where I still cannot download it.
https://tfc.tv/show/details/4752/meet-me-in-st-gallen
Any instructions as easy as a 5 year old to follow would be great. -
For anyone following, I think I may have an update. It looks like I might be downloading the video incorrectly.
Any suggestions on how to download videos that don't have direct links to a m3u8?
I can DM the login details if needed -
bro they wont show you the method but they will help you download the file.. if u need my help pm me.. found a way to successful download it...
Any update here on how to download the videos from tfc.tv? I would really appreciate it if someone could direct me. I used to use tubedigger a paid version, but somehow some of the videos now can not be downloaded, it is encrypted. Here is the link on one of the videos there with a paid subscription is required: https://tfc.tv/episode/details/220215/fpjs-ang-probinsyano-march-30-2021
Video Download Help From TFC.TV
By Yamiraan in forum Video Streaming DownloadingReplies: 11Last Post: 20th Jun 2021, 14:33 -
Can Livestream videos be downloaded?
By PlzHalp1424224 in forum Video Streaming DownloadingReplies: 4Last Post: 12th Nov 2020, 05:08 -
Downloaded Camera Videos from huaweip10 and they got corrupted
By alimustafakhan in forum Newbie / General discussionsReplies: 4Last Post: 1st Apr 2020, 13:58 -
Can We Control Which Videos Are Downloaded From A Long Playlist?
By abrogard in forum Video Streaming DownloadingReplies: 2Last Post: 8th Jan 2020, 15:33 -
Does Exist Videos Sites Than Can't be Recorded or Downloaded?
By devilcoelhodog in forum Video Streaming DownloadingReplies: 3Last Post: 14th Mar 2017, 08:31
