Hello.
I'm new to the 4K Bluray game.
I wanted to ask this:
I have a full untouched 4K Bluray folder in my hard disc.
With MPC I can play just the film without any problems at all.
What player is there that supports 4k Bluray menu playback?
I can't play it with PowerDVD ultra 19, nor with Leawo.
Also, I bought this (i don't have it yet):
https://www.ebay.co.uk/itm/264849119450
Will i be able to play a UHD Bluray menu from a disc with it?
Edit: Ok, I found the answer to my first question:
DVDFab Player 6, plays the menu just fine.
DVDFab Player 6 is supposed to be able to play a UHD Blu-ray disc with the LG-BU40N but you may need to use their UHD drive tool. See https://www.dvdfab.cn/4k-uhd-drives.htm
Note that I have never tried DVDFab Player 6 because I don't need to. When I decided to build a new PC in 2018, I chose components that comply with Power DVD Ultra's requirements for UHD Blu-ray playback.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thank you for your reply.
I read about the UHD drive tool, although I don't understand much about firmware etc.
I don't want to copy or rip UHD Bluray discs to my hard drive.
I just want to be able to play them.
Anyway, I hope I can with this drive. -
I am less sure about DVDFab Player 6 Ultra's ability to play UHD Blu-ray discs now than I was last night. There is changelog information about DVDFab Player 6 posted in VideoHelp's software section that mentions "UHD Blu-ray discs". Today, when I went to DVDFab's website to check DVDFab Player 6 Ultra's features description, the webpage only says that it plays "UHD Blu-ray". Since DVDFab Player 6 Ultra's webpage doesn't specifically say "UHD Blu-ray discs" that could mean that it can only play pre-decrypted copies of UHD Blu-ray discs.
However, in order to play UHD Blu-ray discs directly, DVDFab Player 6 Ultra software has to be able to decrypt them. Since DVDFab's UHD Blu-ray ripping software needs "friendly" drive firmware to decrypt UHD Blu-ray discs, I expect that DVDFab Player 6 Ultra also needs "friendly" drive firmware to decrypt them.Ignore list: hello_hello, tried, TechLord, Snoopy329
How to play Bluray MENU on TV media player
By samards in forum Software PlayingReplies: 19Last Post: 1st Jul 2020, 15:14 -
bluray disc from folder to iso And a picture in the virtual disc icon
By CapricornX10X in forum Blu-ray RippingReplies: 3Last Post: 27th Jan 2020, 13:01 -
Ripping Episodes from my Bluray-Disc
By JonNada in forum Blu-ray RippingReplies: 1Last Post: 2nd Jan 2018, 02:20 -
Why bluray player doesn't read the bluray disc?
By mastersab in forum DVD & Blu-ray WritersReplies: 5Last Post: 31st Dec 2017, 08:12 -
Bluray Mkv to normal bluray disc
By Igniz in forum Video ConversionReplies: 3Last Post: 10th May 2017, 23:15
