I thought that MkvToolNix was supposed to be lossless when muxing but when I open an MKV, take the bottom audio track and move it to the top (default) position then remux, the file size goes from 10.2 gigs to 9.3 gigs. So this is obviously not lossless.
Am I doing something wrong? Because every time I do this I lose file size.
Results 1 to 14 of 14
If your input is a transport stream then the loss might be:
a. due to lower container overhead (transport streams can have humongous overheads)
b. loss of bit rate stuffing.
Not totally sure, cut iirc if you feed content with truehd(ac3) combi-streams only the truehd part is kept.
-> if you want something more qualified, share more details on what you are doing,..
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Ya, the default audio stream to start with is TrueHD Atmos 7.1. The second one is AC-3 5.1. I move the AC-3 to the top(default position) above TrueHD.
This is how it starts.
[Attachment 57652 - Click to enlarge]
I just click and hold the AC-3 track and drag it above the TrueHD Atmos then click "start multiplexing". So by doing this am I hurting the TrueHD Atmos track in anyway?Last edited by agon024; 4th Mar 2021 at 16:08.
weird. afaik you can only click/hold and drag a track DOWN the list with mkvtoolnix. and not sure how you got that as a 10gb file as it's 48gb off the disc.
Actually, I can't remember mkvtoolnix without being able to move tracks both up & down. You can also activate buttons for it in preferences.
[Attachment 57663 - Click to enlarge] -
agon024 what version of mktoolnix are you using? i'd suggest updating to the latest and trying again to see it if makes a difference, as older versions had ways to shrink file sizes that aren't used anymore for compatibility reasons.
You got me doubting. I just checked by adding a mpls from BD ISO which contains both TrueHD with embedded AC3 and DTS-MA. I can move all audio-, video- and PGS tracks independently up and down. Both with the buttons and by dragging. I am on latest version 54.0.0. Only item that won't move is 'chapters'.
thanks for letting me know. here all dragging up does is highlight everything on the way up.
This is not true. Mkvmerge just separates the combined track into 2 separate tracks.
https://gitlab.com/mbunkus/mkvtoolnix/-/wikis/TrueHD-and-AC-3 -
LOL - thanks Moritz! in the new v55 i can once again drag and drop up or down.
mkvtoolnix
By vega69-ux in forum EditingReplies: 3Last Post: 25th Sep 2020, 20:54 -
about MKVToolNix
By ujang in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2018, 23:32 -
MKVToolNix Help!
By Alekos65 in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2017, 01:26 -
MKVToolNix
By ThomasCSR in forum Video ConversionReplies: 6Last Post: 14th Jun 2017, 12:19 -
MKVToolNix 9.7.1 help
By zcool2016 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jan 2017, 02:07
