Hi,
I am trying to make a Blu-ray disc with a number of .mp4 files that have Dolby Vision (profile 5), but tsMuxeR gives me an error message saying that the format is not supported when I try to open them. Any idea why and how I can fix it?
These are professionally authered files by Diversified Video Solutions which are meant to be used for TV calibration of Dolby Vision with a colorimeter. The demo files can be found here: https://diversifiedvideosolutions.com/UHD_Project/Dolby_Vision_Test_Pattern_Demo.zip
Any instructions how to do that? And why? I thought .mp4 and Dolby Vision were supported formats.
Eventhough both Dolby Vision sources and mp4 files can be accepted by tsMuxer, doesn't mean all of them are suited for UHD-BD muxing.
Actually, now being in the learning process regarding Dolby Vision, I dare say mp4 with Dolby Vision are often a special treat and not compliant or backwards compatible to UHD-BD. Should you be interested, there's a lot of talk about Dolby Vision at a.o. the forums at makemkv.
About your mp4 demo links, MediaInfo states color range being "full", which I honestly would not know to be UHD-BD compliant.
AAC audio is not supported in UHD-BD for sure.
Nevertheless, you can give latest nightly build of tsMuxer a try. Maybe it'll do the trick for you and will remux into BD.
Where I would be quite suspicious to loss of significant meta-data, TBH (if not already introduced during mp4 mux).
UHD BluRay archiving & HDR10+/Dolby Vision
By hypersucker in forum Blu-ray RippingReplies: 5Last Post: 21st Sep 2019, 15:45 -
Dolby atmos 7.1 sound into simple 5.1 sound with tsmuxer 2.6.12
By fits79 in forum Blu-ray RippingReplies: 1Last Post: 8th Jul 2018, 12:43 -
MP4 file won't open, not much in MediaInfo
By koberulz in forum Newbie / General discussionsReplies: 13Last Post: 7th Jul 2018, 08:42 -
HDR and Dolby Vision
By Case in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2018, 13:29 -
Mp4 file won't open and has no media info
By killercuddles in forum Video Streaming DownloadingReplies: 5Last Post: 21st Nov 2016, 06:12
