I'm sure that many have encountered the inevitable blank spots on home videos. They are those one-to-two second gaps of blank tape. The trouble is, that VirtualDub goes to a blank screen, when it encounters one of these. The video capture does not resume, once the signal returns. I need to re-cue the tape to that spot, and initiate a new capture.
My question is: Is there a setting that I can change, to prevent this? Or, is it a problem with the capture device? On a related note, I would like to be able start the capture, before I actually start the tape---so I don't miss the first couple/few seconds. I could always edit-out the blank portion later. But, this doesn't seem to work. I will get audio, but no video.
Not necessarily true. VirtualDub seems able to reacquire the video signal, if the interruption (blank segment on the recording) is not much more than a second. Longer than that, and it seems to give up trying. That was why I was wondering if there might be a setting in the capture mode.
Or, the fault could lie in the crappy capture device that I was using. I have better on-order. So, I will see if the issue persists.
Capture/reconstruct video from RF signal
By swiego in forum RestorationReplies: 11Last Post: 26th Dec 2018, 04:50 -
VCR signal noise during capture
By ghiga_andrei in forum Capturing and VCRReplies: 12Last Post: 6th Jun 2018, 05:12 -
EasyCap shows up as OEM Device in VirtualDub - No video signal! How to fix?
By elgy in forum Newbie / General discussionsReplies: 1Last Post: 24th Mar 2017, 10:36 -
Composite Capture from VHS -- lose signal
By poncho524 in forum Capturing and VCRReplies: 3Last Post: 20th Sep 2016, 07:30 -
Can't capture signal from JVC HR-S9911U VHS deck into Hauppage capture card
By vhscapture in forum Capturing and VCRReplies: 3Last Post: 18th Jul 2016, 12:07
