Megamix-LAVFilters-0.74.1-92-x64
Player: MPC (from this package)
Projector: Epson EH-TW 9200
I finally exchanged my trusty old computer with an 11 year old Intel Core 760 and Nvidia 1070 to a brand new AMD 5800X and a RTX 3080.
The old computer used MADVR like a charm (NGU Sharp High), while of course had massive problems with downscaling or high performance settings. Still 23.976, 25/50 and 30/60 were butter smooth.
With my new computer I used the same settings and wanted to go o from there. While the CPU was almost idle at 5% and the GPU at 30%, I had massive stutter in 23.976.
No problems in 25/50 or 30/60.
In the end I turned off every "trade quality for performance" option and went crazy with NGU Anti-Alias or Sharp in the highest setting. The CPU is still bored at 15%, the picture quality is fantastic, but still stuttering with 23.976.
The stutter is like this: some seconds super smooth, suddenly it stutters. Again super smooth, then some stutter. With stutter I mean that eg smoke or water is looking like 10-15 FPS, (mostly horizontal) scrolling ist like 10-15 FPS.
No frame drop or any other problem can be seen with crtl+J.
I guess this is only a small setting I did not find so far, but after several hours I come now here to humbly ask for help.
When my old PC could provide the smoothest output on 23.967, I can't guess why the new computer has suddenly this problem.
Since I did not change anything with my projector (even the same HDMI cable) it must be a software setting.
Results 1 to 12 of 12
Are you actually saying that the issue is only with output via the projector or does it happen also direct to your monitor ?
My monitor can only display 60Hz. When I force a 23.976 movie on 50 or 60Hz on the projector I have the same output quality like on the monitor: kind of smooth, but if course frame repetition due display and source not in sync.
I am struggling to find a RTX 3800 GPU. Did you mean RTX 3080 ?
I am inclined to look for a setting on the GPU. -
I am afraid I can not assist further.
All the reviews I read concern the gaming capabilities of the card. It appears to be a 4K card but can be used with a 1440p monitor (refresh rates would be higher than 60 hz(. It also uses hdmi 2.1.
But I would still persue the documentation. Also this is NOT a cheap card and the manuf should give some form of user support. -
One final thought.
Did you post here because there was no solution over at the 'official' thread(s) at Doom9 ?
Could it be that with such a new GPU that MADVR is not compliant ?
I do not use it and I suspect my humble PC is even less powerful than your old one. But I have no playback issues either in MPC-HC or VLC with 23.976 video. -
I did not try this, but this is the doom9 solution: https://forum.doom9.org/showpost.php?p=1862365&postcount=2
If you have a Nvidia 20xx/30xx video card and you encounter micro stutter while using madVR without actually dropping frames, please try the following:
In the Nvidia control panel, go to Manage 3D Settings, scroll all the way down and set Vertical Sync to 'On'. You can do this either globally or just for the media player exe.
In the madVR settings, go to rendering -> general settings, and uncheck 'enable automatic fullscreen exclusive mode'
In the madVR settings, go to rendering -> windowed mode settings, and set 'how many video frames shall be presented in advance' to 1 or a maximum of 3 -
Maybe you should since, to me atleast, it makes more sense to use GPU settings as well.
One the page you linked the following also struck a chord re GRD etc.
456.38 2020-09-17 fixes recent HDR issues - "[madVR][MPC-HC]: Various HDR issues occur when using the madVR renderer with MPC-HC. [3038381]" This version or above needed for GeForce RTX 3080 and 3090 "Includes support for GeForce RTX 3080 and 3090 -
I'd like to thank you for this post... I also experienced the same issue going from 8600k + 3070 to 5800x and 3090. For me it was fixed by just forcing vsync for the player of choice being used with MadVR. Had no problems with projector set to 23.976Hz or 24.000Hz with any other player except when using MadVR. Still don't understand where the problem comes from though... Is it GDDR6x (3080, 3080Ti, 3090, 3090Ti) related problem or something to with AMD + Nvidia? I'm thinking more something wrong with Nvidia..
Running 496.76 DCH drivers
QTGMC and stutter
By Barrythecrab in forum Video ConversionReplies: 42Last Post: 19th Sep 2019, 06:42 -
1080p 60fps mp4 capture device...that uses device CPU not PCs CPU?
By Blackout in forum Capturing and VCRReplies: 36Last Post: 11th Sep 2018, 12:40 -
Are 23.976 (24000/1001) FPS and 23.976 FPS the same?
By Chibi in forum EditingReplies: 1Last Post: 17th Sep 2017, 12:40 -
Stutter effect?
By naalarcon in forum EditingReplies: 1Last Post: 7th Oct 2016, 18:32 -
is there a way to get rid of this Stutter?
By zanzar in forum Newbie / General discussionsReplies: 4Last Post: 25th May 2016, 18:30
