Hello,
I captured a few old VHS Tapes with Pinnacle Studio 24 via Canopus ADVC 300 in 720x576 DV.
After then I will export the video to mpeg4/ H264. I thought that all my setttings are correct but when I play this on PC the Video is narrower than the original file. But the resolution is 720x576 too. When I play the captured original AVI file here is everything OK only the exported file is narrower and the people seen not natural.
I read many about pixel aspect ratio but I can't understanding this very well
Can You please write me in clearly steps how should I do this ?
1. Capturing in 720x576 to avi
2. When the captured video is on the timeline I click than on the export and choose the settings mp4 VBR to 6mbs. And the resolution as Original 576x720
Thank You for Your Tipps.
Peter
dv has non-square pixels. mp4 has square pixels. to convert 4:3 dv to mp4 change the size to 768x576.
You can also remuxing it only (without reencoding)., specifying a DAR (display aspect ratio) of 4:3 (1.333) at container level.
aedipus thank You very much for the Info.
Also when I am on the export Tab I should choose CUSTOM and export with 768x576 ok ?
When my client give my a old tapes to digitalize them I should ask him where will he plays the tapes? When he say ma that he will play the tapes on the TV - here should I export with Original size 720x576 and when he say that he will play this on PC Tablets etc ( square format the pixel ) I should make with 768x576... ?
Thank Yoo -
You can drag & drop your 720x576 mp4 into mkvtoolnix (into the upper panel), in the lower panel select the videostream and set aspect ratio to 4:3 (in the right panel). Then search Multiplex (into the menu bar) and execute multiplex. The result is a muxed mkv with AR 4:3.
If you want an mp4 file you can use my clever Ffmpeg-GUI.
Issues With Colorspace Conversions in VHS Captures
By balderdashian in forum Video ConversionReplies: 0Last Post: 6th Feb 2021, 04:34 -
Capture issues going from VHS to Digital: What is the likely fault?
By ShazimusPrime in forum Capturing and VCRReplies: 5Last Post: 14th Dec 2020, 14:10 -
Image issues Capturing VHS tapes, can't find the cause
By digitalize_it in forum Capturing and VCRReplies: 4Last Post: 1st Dec 2018, 11:49 -
VHS Audio Issues When Using Virtualdub
By mechvhs in forum EditingReplies: 7Last Post: 24th Aug 2018, 14:25 -
VHS/DVD conversion issues
By Irgenie in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Jun 2017, 18:03
