Try DVD Fab Video Downloader and rip Netflix video! Or Try DVD Fab and copy Blu-rays! or rip iTunes movies!
  1. Hello. I record my videos with OBS and I want to remove OBS screen is shown parts such as beginning, or pause continue
    So here what I want to achieve
    With mkvmerge command I want to lets say remove the following parts of the video : 00:00:00 - 00:00:02 sec and 00:21:25 - 00:23:01 in 1 command
    So these durations should be removed from the video and saved as a new video
    I want to be able to provide as many as timespan in 1 command to remove from the video
    Thank you
  2. Mkvmerge only cuts on keyframes, which will be an issue for you unless you have a keyframe at 00:00:02.
  3. Originally Posted by butterw View Post
    so what solution you would suggest me? I want to remove frames where obs studio is visible
  4. you have to re-encode for frame accurate cuts (you could use virtualdub2 if a GUI preview is helpful for the cuts, ffmpeg otherwise) or do the initial recording with keyframes only.
  5. Originally Posted by butterw View Post
    it is not that important to be precise
    I want to cut based on duration. So start cutting at 2 second until 4 seconds. then cut starting 112 second until 120 second. in 1 command
  6. I have found this open source application and looks like what I need : https://github.com/mifi/lossless-cut
