i have one video 1280x720 with very excellent quality video and small size, only 548MB
sometimes i need to convert some video on another format to play on my TV.
for this i use ffmpeg and convert on mp4 with mpeg4 codec or libxvid codec with VBR quality set to 4 or 5.
but big bitrate (2500-3000) are cause to big file (for 120 minutes 1,6-1,8 GB)
this video (nice quality for me) have same duration (120 min) but small size (only 534MB). which codec was used and with what parameters (with ffmpeg)
to get such a small final file?
here video information:
Code:General Complete name : E:\film\REYKJAVIK - ROTTERDAM.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (isom/mp42) File size : 535 MiB Duration : 1 h 22 min Overall bit rate mode : Variable Overall bit rate : 907 kb/s Encoded date : UTC 2018-11-27 22:31:19 Tagged date : UTC 2018-11-27 22:31:19 gsst : 0 gstd : 4954186 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 3 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1 h 22 min Bit rate : 775 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.034 Stream size : 458 MiB (85%) Title : ISO Media file produced by Google Inc. Created on: 11/27/2018. Encoded date : UTC 2018-11-27 22:31:19 Tagged date : UTC 2018-11-27 22:31:19 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 1 h 22 min Bit rate mode : Variable Bit rate : 128 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 75.6 MiB (14%) Title : ISO Media file produced by Google Inc. Created on: 11/27/2018. Language : English Encoded date : UTC 2018-11-27 22:31:19 Tagged date : UTC 2018-11-27 22:31:19
Results 1 to 10 of 10
Video codec is avc which is widely supported by hardware
It's not possible to re-encode a highly compressed file, and keep both quality AND filesize constant, especially when using the same (ex: x264) or a less efficient video codec. -
@butterw
i don't want re-encode this file. this file is great like this. i want information for some other video, ex 1,3-1,5GB to know how to get a final file similar to this, with great definition and small in size... then to have this final result it's thanks to codec x264? with mpeg4 would i get larger files (for the same bitrate)?
@ProWo
what is crf 24-26? -
h264/x264 is a mpeg4-avc codec (as opposed to older mpeg4-asp codecs like xvid).
crf is the single pass encoding setting used by x264, lower means higher quality (ex: crf 23) and higher bitrate. -
Codec does not affect file size.
Simple formula. It's called the 1st commandment of Vhelp. File size = runlength * bitrate. So in your example you can, theoretically, duplicate the result by adopting that bitrate with whatever codec you chose. -
Try my clever FFmpeg-GUI, load the file you want encode, in the video convert section set x264 as encoder and crf 24 and then encode.
Try with other crf values too, until you get the desired result.
What Is The Best Video Codec For Small File Size With Best Video Quality??
By DJboutit in forum Video ConversionReplies: 2Last Post: 14th Feb 2021, 07:58 -
Small Size HD Video After Editing
By JohnMico in forum Video ConversionReplies: 3Last Post: 20th Jan 2019, 10:56 -
Can't figure out video setting for small file size, adequate resolution
By hpcampr in forum Newbie / General discussionsReplies: 5Last Post: 18th Dec 2017, 06:39 -
How to Rip Tv Season dvds into indiviudal small size high quality files
By thomasx in forum Newbie / General discussionsReplies: 9Last Post: 1st Dec 2016, 09:09 -
How To Encoding A Movie Without Quality Loss But Small File Size?
By Encoding in forum Newbie / General discussionsReplies: 15Last Post: 23rd Jun 2016, 17:36
