    Jan 2006
    With the ffmpeg parameter below I'm trying to:
    1: Slow the video by 3.5x
    2: Resize it
    3. Apply Photoshop curves color correction.
    ffmpeg -i test.mp4 -filter:v "setpts=3.5*PTS" -vf scale=1280:720,"curves=psfile=gopher1.acv",format= yuv420p -c:v libx264 -preset veryslow -crf 23 -c:a aac testout.mp4
    But depending on where I put the setpts element, it will either slow it but not resize/color-correct it or it will resize and color-correct but not slow it. Am I doing something wrong? I'm guessing it has something to do with the order of things.
  2. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Not sure but it might be you are using 2 -vf filters separately. -vf is an alias for -filter:v so you might try
    ffmpeg -i test.mp4 -vf "setpts=3.5*PTS" ,scale=1280:720,"curves=psfile=gopher1.acv",format = yuv420p -c:v libx264 -preset veryslow -crf 23 -c:a aac testout.mp4
    Jan 2006
    That's what was causing it. Works great now. I had only used -vf before and wasn't aware the -filter:v was the same thing. Much appreciated.
