I am new to digitizing old analog video. I have dozens of Hi8 tapes (home movies) that I wish to digitally archive.
So, what is a good USB capture device that I can use with VirtualDub? I purchased a Dazzle unit, which came highly rated---only to find that it is total crap! It seems that they took their ancient stock, and put it in a new package. For one, it uses USB 1.0. No one has used USB 1.0 in 20 years! This has resulted in many jumps, inserted frames, and possible audio lag.
I have been trying to find a definitive answer to this question for hours. No luck. Sure, I would love to be able to afford a Magewell. But, that said, what are my other options? I have seen the Elgato and Hauppauge devices mentioned. But, there has also been some question as to whether these will work with Windows 10 and VirtualDub using uncompressed/lossless capture. Does anyone here have practical experience that they can share?
Laptop: Intel Core i7, 64 bit, nVidia GTX970m
Analog playback unit: Sony EV-C100 Hi8 VCR
Input source: S-Video
Results 1 to 13 of 13
Try Pinnacle 500-USB or 700-USB series, The driver may not work well under Wind 10 though.
Unfortunately, both are listed as no longer available (both Amazon and New Egg).Try Pinnacle 500-USB or 700-USB series, The driver may not work well under Wind 10 though.
Well the Hauppauge usb-live2 is supported by Win10 (requires a usb 2 port)
https://www.hauppauge.co.uk/site/products/data_usblive2.html
I can not actually vouch for it since I am on Win7. -
OK, so the choice seems to come down to these two:
https://www.amazon.com/Hauppauge-610-USB-Live-Digitizer-Capture/dp/B0036VO2BI/ref=sr_1...tronics&sr=1-1
https://www.ebay.com/p/127963049
This disadvantage of the Pinnacle is finding a Windows 10 driver. -
Attched a comparison between a s-vhs recording of a dvb-s program, captured with the Hauppauge USB-Live2 and a dvb-s dump
(the raw stream has been saved to disk as received from the satellite) of the same program 2 years later.
The comparison video has been quickly compressed to mp4.
Judge yourself
Thanks everyone, for the advice. Thanks Lollo, for the video comparison. It looks like I will be giving the Hauppauge a try. Surprising, for something so inexpensive.
On a side note, Lollo, I really love that old Gerry Anderson stuff. But then, I am old enough to have watched those shows when they first premiered. -
Back in late nineties, the high end set-top box dvb-s receiver with Y/C output cost me 10 times more than the Hauppauge now; the same for the JVC HR-S9500MS.Surprising, for something so inexpensive.
20 years later (when I finally decided to digitize my tapes
) I am happy to find that the capture device is not the weak link in the chain.
It took so long to start the conversion because in the meantime PC DVB-S card were introduced in the market (and DVDs, and Blue Ray), allowing to
dump the digital stream as it is trasmitted (no loss at all in recording), and I built a pure digital copy of my favourite shows.
On a side note, I also watched Thunderbirs (and UFO and Space:1999) on TV when I was a kid
Good luck with your captures!Last edited by lollo; 2nd Mar 2021 at 13:11.
Thanks. I can still recall when "Fireball XL5" first hit the Saturday-morning lineup in the U.S.. "Stingray" came out a couple years later. "Captain Scarlet" didn't arrive until I was in highschool, and "UFO" not long after. "Space 1999" (my favorite) arrived just as I was starting my third year of college (Engineering). Unfortunately, Gerry Anderson's stuff seemed to drop-off, after he lost Barry Gray doing the soundtrack scores.
chinese usb 3 device capture
By codebox in forum Capturing and VCRReplies: 28Last Post: 21st Jul 2021, 16:20 -
Out of touch with video capture - USB capture device advice
By Lambchop in forum Capturing and VCRReplies: 7Last Post: 25th Nov 2018, 05:19 -
Firewire / USB / Capture device
By GovertdeKat in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 23rd Nov 2018, 12:01 -
Device not detected on VHS to USB Capture-Converter
By Anonymous754 in forum Capturing and VCRReplies: 10Last Post: 26th Jun 2017, 07:46 -
Magewell USB to HDMI Capture Device HELP
By bdizzle009 in forum Capturing and VCRReplies: 2Last Post: 6th Feb 2017, 07:21
