Hello everyone!
I am new here and totally new to editing... Maybe someone can give me some good advice!
I have two videos of the same event in two different angles. Now I realized they are not the same quality. When I look at it it really irritates the eye, because the second one is pretty blurry and its speed seems to be somehow different (sorry I do not have a better way to describe it..) . I assume there is not much that can be done to improve it, if the material is not good to begin with. Yet I would like to ask: Is there anything I could do to make the transition between them a bit better, smoother to the eye? Should I change sequence settings? Use a filter? Make the whole video quality lower to match them? Any tip would be appreciated!
I am attaching a sample of a transition between the first and the second video and the files details from Premiere Pro:
https://www.youtube.com/watch?v=yUnhF5bKrUM
First Video details:
Type: MPEG Movie
File Size: 9.5 GB
Image Size: 1920 x 1080
Frame Rate: 50.00
Source Audio Format: 48000 Hz - 16 bit - Stereo
Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
Total Duration: 00:26:09:06
Pixel Aspect Ratio: 1.0
Second Video details):
Type: MPEG Movie
File Size: 3.0 GB
Frame Rate: 29.97
Source Audio Format: 48000 Hz - compressed - Stereo
Total Duration: 00:26:21:00
You took a 50fps clip and a 29.97fps clip and combined them in a 23.976 timeline?
You're not helping yourself.
Change your timeline to 50 fps.
Cut the clips together as desired. Your motion will be more stuttery with the 29.97 material. You can try to sharpen it up in the lumetri color correction, Don't expect miracles. -
I appreciate your reply!
Actually I can see inside the program, that my sequence IS 50 fps. Am I wrong?
I will try to play with the lumetri color correction, ans hope it helps.
Thank you very much for your help.Last edited by Laer; 1st Mar 2021 at 16:13.
Labeling people on home videos - advice wanted
By Theodore in forum RestorationReplies: 7Last Post: 4th Jan 2021, 04:30 -
Looking for advice on editing 15 years of home videos...
By lordhutt in forum EditingReplies: 14Last Post: 21st Dec 2020, 23:13 -
Seeking advice on videos from Samsung S8+ ? no HDR ?
By hydra3333 in forum Newbie / General discussionsReplies: 8Last Post: 20th Oct 2018, 17:50 -
Want to edit home videos but need advice
By ZeroG in forum Newbie / General discussionsReplies: 46Last Post: 31st Jan 2018, 16:50 -
Format advice HD videos to create DVDs
By Y Spencer in forum MacReplies: 4Last Post: 12th Dec 2016, 19:03
