What are the pros and cons of shooting in a higher resolution than what the final render is going to be? Let's say you shoot 1080P/60 but you know the final product will be 720P/30? Do you gain anything by doing this? Are there artifacts created during the render process? I come from an audio background and the process of converting one sample rate to another, slower one involves dithering and that can create artifacts. This is why I ask.
Thanks!
Every Hollywood movie is done this way on a larger scale. It allows for re-framing during editing and a "future-proof" archive. As long as you don't bit-starve your final output it is fine. You will lose some sharpness and detail, but it will generally look as good or better than if you had started with 720 to begin with.
Your most noticeable change will be the frame rate, which will either result in a mushier look if you choose to blend it, or less smooth motion if you choose to sample it. That said, 720p/60 is also a viable option.
Why do people say TV shows shot on film were higher resolution than...
By 90sTV in forum Newbie / General discussionsReplies: 56Last Post: 28th Nov 2021, 11:36 -
render mistake in resolution
By gta5 in forum Video ConversionReplies: 7Last Post: 30th Jul 2020, 05:56 -
Higher resolution
By Oleander in forum Newbie / General discussionsReplies: 10Last Post: 20th Oct 2019, 09:30 -
Best Video Converter for Upconversion to Higher Pixel Resolution?
By pone44 in forum Video ConversionReplies: 8Last Post: 14th Jun 2019, 08:51 -
Do 480p videos look any better on higher resolution TV screens?
By Video_John in forum DVB / IPTVReplies: 37Last Post: 8th Nov 2017, 12:00
