I was given two files of the same movie. Both 2160p.
The smaller one is HEVC.
The larger one is AVC.
Here are the the Mediainfo for both:
HEVC
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L6@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 3 h 28 min
Bit rate : 17.3 Mb/s
Width : 3 840 pixels
Height : 2 080 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.090
Stream size : 25.1 GiB (98%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1014 cd/m2
Maximum Frame-Average Light Level : 263 cd/m2
AVC
Video
Format : AVC
Format profile : High@L5.1
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 3 h 29 min
Bit rate : 46.1 Mb/s
Height : 2 076 pixels
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.241
Stream size : 67.5 GiB (97%)
Writing library : x264 core 157 r2969 d4099dd
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.30 / pb_ratio=1.20 / aq=3:0.80
Language : English
Default : Yes
Forced : No
I intend to play the movie on LG OLED 65".
I admit I'm not familiar with most of the technical data above.
Could someone advise me which of those two alternatives might give me a better picture? (whatever "better" means...)
Thank you
Results 1 to 16 of 16
"given two files of the same movie"
you don't own it. that's piracy. don't ask for help. sorry.
p.s. watch whichever one you prefer.--
But, but...it's, it's home movies of my nieces and nephews on family vacation...ummm...yeah, home movies!
J/K...100% pegleg and eye patch stuff!
The first is HDR while the second appears not to be.
That could be an issue; I don't think HDR has all it's kinks worked out due to lack of standards.
My TV has basic HDR10; sometimes it burns your eyes out - like looking at the sun.
The literature talks about "speculative highlights" and "deep shadows" but reality is
miles away from this -
The AVC video probably has a little more detail detail. The first video is HDR and should have more dynamic range if you're set up to play HDR properly. It's up to you which looks better.
It's against forum rules to discuss pirated material. Ask where you got it from.
Any new alternatives to MediaInfo or GSpot?
By Djard in forum Newbie / General discussionsReplies: 7Last Post: 28th Dec 2020, 22:25 -
New alternatives to older software?
By tpapictures in forum DVD RippingReplies: 12Last Post: 11th Feb 2019, 00:27 -
Are there any PlayOn Alternatives?
By peteyallison in forum Video Streaming DownloadingReplies: 2Last Post: 11th Jun 2018, 10:03 -
Software alternatives
By Joelgas in forum ComputerReplies: 6Last Post: 30th Oct 2017, 12:53 -
Any alternatives to yade X?
By pixel zombie in forum MacReplies: 1Last Post: 1st May 2016, 10:47
