Try DVD Fab Video Downloader and rip Netflix video! Or Try DVD Fab and copy Blu-rays! or rip iTunes movies!
Results 1 to 21 of 21
    Jan 2019
    hawai
    video link
    https://it.chili.com/content/operation-endgame-2010/9b0dd63f-5cc9-470c-b6da-9911b87dd6bc
    first: every browser on chili site detects an ad-block... then is impossible to play video (how to?)
    second: find mpd but if video is unplayable how to find key?
    Mar 2019
    Germany
    It is a VPN issue. They know that you're not from Italy. But you can still trick them by adding a header x-chili-user-country=IT
    And they use Widevine.
    "url":"https://chilitv-vod-dash.secure.footprint.net/s/pr/vod/content_22/FW02175_IT2M/FW02175_IT2M_ita_SDHD.mpd",
    "quality":"HD",
    "language":"ita",
    "authenticated":false,
    "codec":"mpd/cenc+h264",
    "subtitles":{
    "url":"https://chilitv-vod-dash.secure.footprint.net/s/pr/vod/content_22/FW02175_IT2M/FW02175_IT2M_ita_SDHDP.mpd",
    "quality":"HDP",
    "language":"ita",
    "subtitles":{
    "url":"https://chilitv-vod-dash.secure.footprint.net/s/pr/vod/content_22/FW02175_IT2M/FW02175_IT2M_ita_SD.mpd",
    "quality":"SD",
    "language":"ita",
    "subtitles":{
    Jan 2019
    hawai
    this behavior i have on some browser without ad-block extension and/or with ad-block extension (disable). all browser. i think is a bug of site chili.com...
    also one my friend, who lives in Italy, have same problem...
    then explain better how to put adding header (you able to play this video from browser?)
    Mar 2019
    Germany
    You can use https://chrome.google.com/webstore/detail/modheader/idgpnmonknjnojddfkpgkljpfnnfcklj or similar extensions where you can enter a header. I disabled Adblock and then I was able to play it.
    Install the extension and click on that plus ➕. Then enter x-chili-user-country with the value IT
    Jan 2019
    hawai
    you write: <I disabled Adblock and then i was able to play it>
    very strange. repeat, i have disable my adblock or have used fresh browser without adblock installed but no change, unable to play video.
    and also my friend, on italy, can play this video.
    now i try with your suggested extension.
    edit: try it but no change. installed extension, add header on request, disable my adblock but impossible to play video.
    Jan 2019
    hawai
    Mar 2019
    Germany
    You still need Italian vpn though. It won't work with a random vpn. In my case, I disabled Adblocker, changed vpn to Italy but it didn't work. I saw that the country of origin is still DE. After modifying this header value I was finally able to start the stream.
    Jan 2019
    hawai
    my friend is in italy. no vpn needed. also no http extension. adblock disable and/or new fresh browser. but video don't play!
    Mar 2019
    Germany
    Here I showed you how to do it: https://anonfiles.com/Z4c5la7cq9/cl_mp4
    I don't know what your friend does wrong. Maybe the site is wrong. Who knows..
    Jan 2019
    hawai
    your link not work (for me)
    503 Service Unavailable
    No server is available to handle this request.
    please up file to upload.ee (is free)
    i see that
    [Attachment 57553 - Click to enlarge]
    but on download i have this new window
    [Attachment 57554 - Click to enlarge]
    Jan 2019
    hawai
    yes i know. i use VPN but not work.
    anyway with mpd have download video.ts (3.4GB) and audio file (78MB only)
    but is encrypted. need key to decrypt. but i don't play video, then not have key.
    someone to get key?
  12. VPV should be good.
  13. Originally Posted by lomero View Post
    yes i know. i use VPN for anonfiles but not work.
    and if VPN you mean for chili.com not work.
    anyway with N_m3u8DL-CLI and mpd link i have download video ts (3.4GB) and audio file (78MB only...)
    but all is encrypted. need key to decrypt. but i don't play video, then not have key.
    Someone to get key?
    pm me and ill try to look into it
    Jan 2019
    hawai
    no work for me. unplayable video.
    and undownload anon file! need key to decrypt.
    if work for you, please post here only key.
    Mar 2019
    Germany
    i see that
    https://www.upload.ee/files/12942352/chili.mp4.html
    Here yo go. The key is visible at the end.
    Jan 2021
    Argentina
    There are some extensions that cause that problem, like Windscribe (VPN+Adblock). Although is a bit strange that you also have that problem in a fresh browser.
    Jan 2019
    hawai
    i have disable all my extension. and have same problem.
    then i have rename my Data folder (i use portable version of all my browser) so at startup + as if i had a new installation.
    but nothing solve my problem. maybe is my internet provider...
    @ hvq
    tanxs for your file. but you understand copy key number from your video is a very hard attemp...
    please write here.
  18. Member
    Jan 2021
    Argentina
    I see...
    Whatever, you could try Undetectable AdBlocker or similar as a last resort
  19. Originally Posted by lomero View Post
    but nothing solve my problem. maybe is my provider...
    @ hvq
    tanxs for your file. but you understand copy all key number from your video is a very hard attemp...
    please write here.
    keys 287a173a1d3e41017a5c204a829ab1b2 KID=25d749834e9eaa0c57cd85684cb0d0e5
    Jan 2019
    hawai
    tanxs lfer94 but problem is not which ad-blocker. chili.com (for me) not work always.
    with chorme, firefox, and other browser (i use 10 browser on my pc, each different).
    and with ad-block disable or fresh installation (without any ad-block or other extension installed) same problem.
    i can't play any video from this site (free play with ads). tomorrow i write to chili.com for some explanations.
    @ ChezBompaLawijt
    tanxs for the key. video & audio decrypted. all work correctly. problem solved.
    @ to everybody
    and yes, now all work correctly. with new VPN (set to Italy) work. with another VPN not work and also for my friend (live in Italy) play not work.
    chili is very strange site.
