My video contains many complex overlapping moving parts in 7 layers. I simply wish to push forward all layers in a single 2 minute 13.5 second sweep, to insert a single video at the beginning, ahead of the existing, completed layers. Can someone please save me many hours of individual mathematical conversions, by sharing how I can just create space at the beginning, to move the rest forward? In other words, move entire layer / layers strategically to the right. Thank you!
Next time you open a new thread please put in a more descriptive title rather than "help",for this time i changed your title,more people will help you that way.
What software are you using ?
In most editors, you can group select and move all layers/tracks over all together. It might be left click and marquee select, or ctrl or shift + select to group them
In some you can set a marker on an exact time or place so you can snap to the exact spot -
In some editors, you can change the timeline forth then back. So timeline was starting at 01:00:00:00, you change it to 01:02:00:00, then you change it back to 01:00:00:00 but change mode so it doesn't let assets snap back. Now your first asset starts 2 minutes later and you just fill in.
Or
Some editors let you nest one timeline in another, so your original gets nested in another, where the original comes after the new elements.
Or
Just render your timeline as-is. Then create another timeline of new elements with same properties, render it. Then append the 2 together w/o re-encoding (in a diff app, like avidemux, ffmpeg).
Lots of ways.
Moving a section of the video to the right
By pooksahib in forum EditingReplies: 2Last Post: 28th Jan 2021, 09:23 -
Moving between Windows and Mac: Capture/Edit/Convert Workflow
By Christina in forum Video ConversionReplies: 0Last Post: 13th Aug 2020, 18:34 -
How to add moving line in video?
By SinghLive in forum EditingReplies: 4Last Post: 6th Dec 2019, 16:10 -
Video Player to Do Side By Side (overlapping) Comparisons
By ilgrank in forum Video ConversionReplies: 20Last Post: 1st Dec 2018, 04:04 -
Its possible to remove a moving watermark from a video ?
By Darth_Vader in forum Newbie / General discussionsReplies: 10Last Post: 23rd Jan 2017, 11:41
