Hi
I want to upscale some DVD's to BLU-RAY using Topaz AI Video. The software will turn the video both progressive and interlace into thousands of TIFF images then enhance them one by one. I've tried to learn about AviSynth+ and FFmpeg with limited success.
My specs:
Win 10, i9-9900k, 64GB ram, Nvidia 2070 super, 8TB ssd 4TB nvme.
My work:
Mostly anime.
What software is available that can stitch the TIFF images back into a H.264 or H.265 codec, ready to be burned to BLU-RAY?
I need something that encodes and authors in one go. I don't want to re-encode if possible for quality reasons.
Would TMPGEnc Authoring Works 6 be good or DVD Architect Studio? Is there any software that stands out for quality and ease of use?
I have not found any good tutorials that cover this.
I realise many of you are tired of answering newbie questions , but this is important to my mental health, I need a project right now. My country is in lock-down until July so any assistance would be greatly appreciated.
Thank you
Results 1 to 15 of 15
"stitching" is the wrong term. You can make a video from many images with FFmpeg, have a look here: https://trac.ffmpeg.org/wiki/Slideshow
You can also do it with the free version of Davinci Resolve.
Michael -
Thank you for the response,
I did'nt think anyone would answer. I've heard good thing about FFmpeg but I have not seen a tutorial that explains things. One came close, but then he skipped the FFmpeg bit as if everyone knows about colour space and framerate.
I am trying, but its not easy finding your way out of a hedge maze in the dark. Is Davinci Resolve well regarded on the forum? Is the quality excellent? I don't mind paying for a simple high quility piece of software.
Thanks again. -
If your operating system is Windows, I can give you an example for a FFmpeg script. What are the filenames of the images? The size (width*height) of the video shall be the same as the size of the images, right?
As an introduction see also my book: http://www.astro-electronic.de/FFmpeg_Book.pdf
Yes it's excellent but it has so many functions that you don't know where to begin. You need a good book or watch many video tutorials.
The free version of Davinci Resolve is sufficient for what you want to do.
Michael -
Hi,
Sorry for the delay I was trying to read the book. So you literally wrote the book on FFmpeg
Davinci Resolve does look good but overwhelming. VirtualDub2 is much easier to work with.
I think I've worked out the code I need in FFmpeg, is this correct?
ffmpeg -r 50..00 -f image1 -s 1440x1080 -i %06d.tiff -vcdec libx264 crf 0 -pix_fmt yuv420p
I've experimented with StaxRip and QTGMC trying to deal with interlace in the smartest way possible.
Will I need to re-encode when I insert chapter points?
Thanks -
You should enter chapter points when you encode. An IDR (real keyframe) has to be inserted for BD at chapter points for navigation. This is usually done with a QPfile. There is a utility called chaptergen that can help with this, but the qpfile name/path has to be entered in the x264 encoding string
CRF 0 is incompatible with BD. You should use BD compatible settings if you're going to author it on a disc (a real BD with menus, compatible on a BD player) . Not a "data disc"
https://sites.google.com/site/x264bluray/home
You should use "Rec709" to convert back to YUV, assuming that's what you used to convert to the TIFF images , otherwise there will be a color shift
1440x1080 @50fps is incompatible with BD . The highest resolution @ 50p is 1280x720 . The other option is to make it interlaced 1920x1080i25 (50 fields/second interlaced) if you need the temporal resolution
None of those tools "author" a disc . You still need to author it with something like DVDA, Encore (discontinued) . TSmuxer can, but without menus. -
davinci resolve:
Find the size of your images (aspect ratio)
Open DV Resolve.
Gear wheel icon bottom right, set custom aspect ratio and choose your fps for timeline and playback
(make them the same fps, you must set fps before importing media)
Along the bottom of the window, use the media tab to import the image sequence (typical folder tree left hand pane) drag the sequence to the bottom window.
If you can't manage that, open file explorer and drag and drop to the bottom window of the media pane.
Go to the edit tab, use the media pool top left, drag sequence to timeline, play and or edit to your hearts content.
Head to the deliver tab, choose your output and render. job done
Dv Resolve is brilliant for image sequences as long as you can cope with H264 (in the usual containers)
Virtual Dub would be a good choice, very flexible with some basic filters.
File/ Open Video, make sure 'linked segments' is checked
It may take a moment to import, especially tiffs.
Video tab, set frame rate
Video tab set compression, choose your desired compress
Save video as
Job done.Last edited by super8rescue; 28th Feb 2021 at 11:17.
Try this command line:
ffmpeg -framerate 25 -i %06d.tiff -r 25 -y out.mp4
If you start FFmpeg from a Windows batch file, you must replace "%" by "%%".
The -framerate option tells FFmpeg how fast to read in the pictures.
The -r option is the output framerate. The default is 25, so you could omit this option is 25 is ok.
The -framerate and -r values can be different. If -r is larger than -framerate, then images are duplicated if required. If -r is smaller, then some images will be skipped.
In this case it's unnecessary to specify the video codec because h264 is the default.
Michael -
Hi
Won't I lose %50 of the quality by discarding the frames. I thought doubling the framerate preserved the quality of interlaced content. Most of the DVD's are 4:3 ratio hence the 1440x1080 when upscale. How do I keep the ratio and prevent distortion if I can't use that resolution?
What is the lowest CRF that is valid for Blu Ray?
I think Topaz AI Video does not include black bars when converting 4:3 video to images. If it did, I could use the standard 1920×1080 is there a way off inserting the black bars while authoring?
Also some of the original framerates are strange 29.970 and 23.976.
This is the link I'm using as a reference. Its not much but it's the closest I've got to explaining the basics.
https://www.youtube.com/watch?v=FZhgK-SBlFQ&list=FLTyayUx9dhiB3Y6SUt7tlfQ&index=36
Would multiAVCHD be any good?
Thank you all for your patience -
If the DVD is theatrical such as Hollywood, or TV drama from North America (unlikely since you're using "50p"), it should be inverse telecined, not deinterlaced, and the original frame rate should be 23.976p
If the DVD is from a UK drama series, it should be "25p"
Only things like reality TV, sports, some concerts might be interlaced "25i" , or "29.97i" . Those have 50 fields/s or 59.94 fields/s and smooth motion
All that proper preprocessing should have been done before VEAI, otherwise you'd get inferior results in VEAI
Typically, 4:3 content is pillarboxed in 1920x1080 for BD, you can do that when encoding
CRF is typically not valid for BD unless you specify vbv maxrate and buffer size. Uncapped CRF can result in peaks and buffer underflows for BD. It's not recommended for BD. Generally you want to do 2pass with VBV because you need an exact filesize for authoring (fixed media size), this will result in better quality and even distribution. "Capped" CRF with VBV can lead to artifacts
Multiavchd can work, but it's depreciated for many years . It can accept avs scripts (you can open image sequence in the script), so you'd only have to encode once -
For BD, 1920x1080 is typical, but 1440x1080 is allowed per the spec (as well as 720p & SD rez). Much here depends on which encoding & authoring app you are using. AFA bitrate goes, there shouldn't be much difference between either one, as pillarbox bars take up almost no bitrate.
Scott -
I apologize - PDR is correct. Ignore what I wrote above and return to your scheduled programming. That option was clearly meant for HDV and similar non-square assets.
Certainly wouldn't want to have it be stretched out to 16:9!
Batch Script for FFMPEG TIFF Conversion
By Jolly Green in forum ProgrammingReplies: 5Last Post: 30th Sep 2020, 15:11 -
Can't convert .tiff's to lossless video [color problem]
By eobardthawne in forum Video ConversionReplies: 6Last Post: 8th Oct 2019, 13:39 -
Windows 10 tiff file not recognized when created by PANA LINK program
By bevills1 in forum ComputerReplies: 3Last Post: 15th May 2018, 16:42 -
Images to Video
By AnthonyHunt in forum Newbie / General discussionsReplies: 8Last Post: 26th Feb 2017, 01:22 -
x264 and still images
By Mavrodi in forum Newbie / General discussionsReplies: 7Last Post: 23rd Nov 2016, 14:55
