The file I'm trying to burn to DVD has three parts to it (three parts but one file). Is there any authoring software which will allow me to add chapters for ease of access as usual, and then also allow me to add another submenu, with links to the three parts of the file? We don't want to just have three different files on the DVD. Recommendations appreciated, including free and professional software.
A software called "GUIforDVDauthor" should be able to do what you wish and it's free, but can be a bit cubersome to use. DVDStyler seems to be more user friendly but personally I haven't used it. I would try DVDStyler frist, as suggested by videobruger.
Personally I use and recommend DVDMaestro. Admittedly it is ancient, but works really well for doing advanced authoring once you know how to use it. I do not recommend it for the unexperienced user though, it has a steep learning curve and requires you to create all assets externally (menus, subpics/buttons).
Creating an DVD-authoring software
By dvdmaster1 in forum ProgrammingReplies: 5Last Post: 30th Mar 2022, 17:56 -
DVD Authoring Software
By flarimeki38 in forum Authoring (DVD)Replies: 6Last Post: 11th Dec 2020, 16:09 -
DVD Authoring Software advice
By 3-Phase in forum Authoring (DVD)Replies: 8Last Post: 20th Nov 2019, 18:41 -
Need recommendations for DVD authoring software.
By AlliS in forum MacReplies: 3Last Post: 2nd Jan 2019, 22:09 -
Whats the Best DVD Authoring Software
By jcool26 in forum Authoring (DVD)Replies: 29Last Post: 28th Jun 2016, 13:15
