I've never encountered this issue with AutoGK and any DVD before.
There is no copy protection, I've got all the files of the DVD copied to a folder and am not trying to rip straight from the disc, I've tried straight file copying via Windows Explorer and again with DVD Decrypter anyway.
There are 5 VOBS and 2 IFO files. I've run the right IFO with the correct 90+ minute PGC length through AutoGK twice and both times even though the log says it's processing all VOBs in the directory it keeps outputting only 5 minutes worth of AVI and I don't even think it's the first 5 minutes of the movie.
I also tried a program called AVI.net that's listed in the programs here, had never used it before, but it gives the exact same results.
Oddly I tried the freeware version of Wonderfox DVD ripper which has a built in 15 minute rip limit, and it actually produced an AVI of the first 15 minutes, breaking the 5 minute threshold I was stuck at with all other programs, but I don't want to pay for the full version just to rip this one problematic disc.
Not sure if it's related by when I try to input the IFO file in AGK that's not associated with the feature length movie PGC it gives a parsing error, but the 2nd IFO file does input but again as I stated I'm only getting a 5 minute AVI file.
autoGK is now quite an old program and only gives you xVID or DivX avi both of which are now out-dated.
Try vob2mpeg to see if that will create a single mpeg2 of the main movie or load the folder in to handbrake and see what that does (it should report 90+ mins) and encode in a more up-to-date codec from there. -
Use pgc.NET a rather old but still very useful tool from the same author as Avi.NET and choose the largest vob-90min one. Then run it through Avi.NET. It should transcode to Xvid fine now. Failing that you may need some sort of vob repair tool. I think there are some on this site.
https://www.videohelp.com/software/pgc.NET -
AVI plays fine..3 minutes, but no metadata, says it's only 8 seconds long
By TomTom in forum Newbie / General discussionsReplies: 11Last Post: 12th Oct 2019, 12:55 -
Combining AVI files in Virtualdub gives the wrong length video...?
By kelemvor in forum Video ConversionReplies: 8Last Post: 24th Jun 2018, 21:21 -
How to add permanent subtitles with AutoGK and convert to AVI DivX or XviD
By Baldrick in forum SubtitleReplies: 263Last Post: 17th Jun 2018, 15:18 -
Will a Sony DVCAM DSR-20MDP play 60 minutes on a tape recorded 60 minutes?
By snufsis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Jun 2017, 20:00 -
Will only rip 4 minutes of dvd
By DaveB69 in forum DVD RippingReplies: 14Last Post: 11th Apr 2017, 13:20
