  1. Hello,
    When i capture video8 from dv.now capturing card through fast.forward SW. It gives me "file.dif". I want save this files on HDD, because signal on original tapes is getting worse by time. And i would like to cut some scenes from this files and save it again as "file.dif". But i can not find any SW which can do this.
    Could you please give me advise? Of cause, i do not want re-encode files so i am looking for a SW like ReDo do this with .mp4, or VirtualDub2 with .avi.
    Thank you.
  2. I use Win7 or Win10. But XP i have too.
  3. Member Cornucopia's Avatar
    *.DIF is (should be) just an alternate label for *.DV, which is that container-less muxed stream straight from the cam. Just rename the extension (to *.DV).
    Lots of apps should accept this format, though still less than if it was in a multimedia container format.
