    Feb 2013
    The shaking lines. I've seen this with a lot of uploads of old NFL broadcasts:
    https://www.youtube.com/watch?v=MH0iffeqeI4
    Feb 2013
    Any ideas?
    Mar 2008
    What shaking lines are you talking about?
    I suspect the reason you didn't get a response is because no one knows what you mean
  4. Poor deinterlacing and incomplete dot craw removal. Exacerbated by upscaling SD to HD.
    Feb 2013
    Is there a reason just about every professional old video transfer seems to have this dot crawl problem (I take it this was probably from 1-inch Type C videotape)?
    I don't know about poor deinterlace. The main errors I see are on pure diagonal lines, and even QTGMC can choke at times. I think the bigger issue is softer capture with bad sharpening post-deinterlace.
    It really does look like a DV conversion. The "KICKOFF" banner at the start of the video really gives it away, all the jaggy red with a hue changes, block noise around the letters. Main lesson here: Don't use DV converters. Those are crap.
