Is there a way to decimate 29.97 video back to 23.976 when it contains slow motion (not real slow motion, the kind with dupe frames)?
I heard that tools like tdecimate get confused by slow motion duplicates and therefore make the rest of the video's decimation inaccurate.
Usually not a problem. eg. Duplicate frame sequences common in certain types of anime DVD's and they are handled just fine
If you have a source with problems you can adjust the settings, or use other decimation methods, or even selectevery
But if the duplicates have noise , or other differences like not stable - then they are not "duplicates" according to most algorithms and that can cause problems
Slow Motion Video Player??
By DJboutit in forum Newbie / General discussionsReplies: 10Last Post: 13th Nov 2020, 04:36 -
Make a slow motion video at a constant rate
By luciofulci in forum Video ConversionReplies: 7Last Post: 29th Sep 2019, 18:51 -
play parts of a video in slow motion in playlist
By cpliu in forum Software PlayingReplies: 1Last Post: 5th Mar 2018, 00:03 -
which video editors have great slow-motion effects?
By shun in forum EditingReplies: 7Last Post: 29th Nov 2016, 12:13 -
using avisynth to make part of a video slow motion
By pooksahib in forum EditingReplies: 4Last Post: 18th Sep 2016, 08:55
