I downloaded a movie to my PC, burned it with my Sony DRU dvd+rw burner, but when I put the disk into my Sony DVP-NP315 dvd player it says"cannot play this disk" what have I done wrong? My dvd player is compatible with dvd+rw, and I think I converted from AVI2MPEG2 correctly:o All help is appreciated.
Hello,
Even if you think your authoring process was good, i d'ont think it was.
PC DVD players can play almost everything even if MPEG2 standard is not respected.
For a PAL movie, you must have a GOP structure like this :
I picture = 1
P pictures= 4
B pictures= 2
and 1 interval picture for chapter informations.
For NTSC :
I picture = 1
P pictures= 5
B pictures= 2
Audio format must be correct too.
I suggest you use TmpgEnc which allow you to control all these parameters and produce very good results. -
I'm going to re-do the whole conversion-author-and burn thing again, because it doesn't look like I'm doing it right. Thanks for the help.
DVD Disk Lock??? i locked my dvd player i need password! (PHILIPS DVP3520)
By kamzo91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Aug 2010, 15:14 -
Will a blu ray disk play on regular dvd player in 480 lines of resolution?
By donfm in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2009, 07:00 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 13:15 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15 -
Burning to DVD RAM DISK and then play on your TV
By pmorris1 in forum Newbie / General discussionsReplies: 5Last Post: 25th Dec 2007, 19:15
