I am completely new to this and have followed this blog to get started: https://macilatthefront.blogspot.com/2021/01/deinterlacing-with-avisynth-and-qtgmc.html
The source video is a VHS of a cousin's birthday shot by a professional vendor, that I had captured via my VCR to PC set-up using OBS (if this is ultimately the issue, I can use whatever the recommended capturing software is)
This video however becomes "wavy" (or what I think is called combing) when there is motion after running QTGMC script - reference images in this link: https://imgur.com/a/0e0RjhV
The top image is the interlaced original and the bottom image is the wavy QTGMC output
Below is my current script:
SetFilterMTMode ("QTGMC", 2)
FFMPEGSource2("First Birthday 98.mp4", atrack=1)
AssumeBFF()
QTGMC(preset="Slower", EdiThreads=3)
Spline64Resize(720,540)
Prefetch(10)
I have tried AssumeTFF() as well as commenting out the resize/sharpening function but I still get the wavy output
Is there anything I can modify, or should I use an alternate deinterlacer
OBS is NOT suggested capture software. What capture device do you have ? Better to use virtualdub and capture lossless lagarith or huffyuv. Even the software that would come with the device would give better results that OBS and NEVER capture as mp4 - there are already combing artifacts in your original.
Those artifacts are from being vertically resized before deinterlacing.
@DB83 - thanks for your advice - recapturing via virtualdub and then running QTGMC fixed the issue
Strange issue DeInterlacing DV capture - QTGMC-Bob (Hybrid Vapoursynth)
By SupermanTV in forum Capturing and VCRReplies: 23Last Post: 17th Sep 2023, 18:00 -
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 03:01 -
Ghosting/Combing after detelecine
By anoli3 in forum Video ConversionReplies: 5Last Post: 14th Nov 2019, 18:39 -
help for combing/etc from progressive video
By spiritgumm in forum RestorationReplies: 10Last Post: 6th Nov 2017, 17:50 -
Why are interlace/combing artifacts only an issue on progressive displays?
By 90sTV in forum Newbie / General discussionsReplies: 12Last Post: 28th Jan 2017, 09:22
