Hi
i'm using a game / chat app . this app doesn't support Gif files as profile image . you can select them as profile image but it doesn't play back , however i see few user manage to trick the system and used an Animated profile image . i try to change the gif file extention to png or jpg but still the image did't play back so i'm assuming those guys used more advanced technique like editing this image code or something ?
is it posbble to Animated jpg sequence as jpg file ? i try png as APNG but that didn't work ether .
i'm sure that they used Gif file but somehow they play with some of the file code or attribute but i don't know how
any help will be great
thanks . the app name is > yalla ludo
i ask but no one tell .
i can't save the images from the app . as i was thinking if i can save one of those guys profile image i would know what type of image they use but sadlly you can't get download images from this android / IOS app -
Probably this: image.jpg.gif
Maybe a script that makes the gif part of the filename invisible.
Have you tried to actually look at the file name of the image?Extraordinary claims require extraordinary evidence -Carl Sagan -
i did change the file extension from .gif to jpg and png but still that gif file didn't play back . you can choose the file even with .gif file extension but no playback .
so far i try
.gif
.APNG
.WebP
but all that didn't help . i think they changed something within the file attribute in order to trick the system into thinking this is just normal image or something .
animated webp test
By poisondeathray in forum TestReplies: 17Last Post: 29th Aug 2023, 15:07 -
How to create animated video?
By JohnPix in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2020, 11:10 -
By JohnPix in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2020, 10:51 -
Restoring Framerate from Animated DVD
By nesburf in forum RestorationReplies: 2Last Post: 14th Feb 2018, 01:43 -
How to do an animated overview of a pdf
By Gaby_64 in forum EditingReplies: 11Last Post: 23rd Nov 2016, 15:17
