Results 1 to 1 of 1
  1. I've this NTSC DVD which displays the following behavior: after QTGMC(), there are some ghosts with purple color and some ghosts with green color. Moreover, there are some not correctly matched frames, as you can see in the attached picture. These duplicates follow some pattern, so it should be possible to remove them.
    How can I restore this to fluid playback and without the color problems?
Name:	since snippet000338.png
