I'm trying to deinterlace a video, I attach a clip. I think it's a PAL-to-NTSC norm conversion (the kind I'd use QTGMC().srestore() on), but it has a weird problem: after deinterlacing, some frames go back and forth. Changing the field order with AssumeTFF() doesn't help.
Simply using QTGMC().srestore(25) leaves lots of blends and dupes.
That video was resized vertically while it was interlaced. That has caused the two fields to comingle. So each field has portions of the original two fields in several bands over the height of the field. There's no fixing it.
Hauppauge USB-Live 2: Top field or bottom field?
By billybatts in forum Capturing and VCRReplies: 3Last Post: 9th May 2020, 04:57 -
Interlacing and field order problem
By Boklavdi in forum Video ConversionReplies: 33Last Post: 26th Apr 2020, 13:05 -
Garbage video with one field messed up
By benzio in forum RestorationReplies: 19Last Post: 25th Apr 2020, 09:41 -
AmaRecTV and field order
By Mr Chris in forum Capturing and VCRReplies: 19Last Post: 16th Aug 2019, 14:50 -
field blended anime (PAL)
By x264 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jun 2018, 06:11
