I have pretty much no experience with DVD-RAM disks or devices. My father gave me an old DVD-RAM disk that he was hoping I could get the videos off of it and either convert them to a standard DVD or a video file.
I checked my optical drive's specs and it did say it supported DVD-RAM disks. When I got the disk it was a mini-disk in some plastic caddy and was two-sided. I took it out of the caddy and tried to read it on my PC.
I was able to view the contents of the disk, but I was not sure how to playback the data, or even if I was playing it back properly.
The disk had three folders on both sides:
DCIM - which other than some subfolders was empty (I assume the camera had some photo feature that was not used)
DVD_RTAV - which contained three files: "VR_MANGR.BUP" "" and "VR_MANGR.IFO" "VR_MOVIE.VRO"
RTR_EXTN - which contained two files "RX.DAT" and "VR_STDUM.000"
I have no idea what any of these files are for, the only one I was able to make any sense of was the VRO file, which since all the others were a few KB in size while that one was in gigs as well as it's obvious filename, was clearly the video file. (I assume the others are some sort of chapter/metadata but I was not able to figure out how to read them after googling about it).
Trying to playback the VRO in MPC:HC or VLC worked..... but only kinda. It claimed the file was only about 3-4 min in length, which makes no sense for compressed video.... and eventually I found out why, the timer just plain doesn't work in any player I used. If I try to skip ahead/rewind it just keeps calculating nonsense times, and keeps going long after the video should have been over.
So I really have no idea what to do.
First of all.... did I even get all the files off the disk right? I just simply copied the files off the disk that Windows could see, but as I said, I am unfamiliar with DVD-RAM disks. Are they designed with any sort of multiple layers or metadata or something of that nature that I would have missed from just simply trying to copy the files as if it was a standard data CD or DVD? And if so, what method should I use to actually read all the data off of it?
And if I did get the data off the disk properly, how do I properly view it? Much less extract/encode it? I couldn't figure out how to try to load the BUP/IFO files to get proper chapter data, or how to even playback the VRO file properly since it's timestamps and playback length were utterly broken. And I have zero idea what the RTR_EXTN folder is even for or if that is some camera-specific metadata that is useless for trying to convert the video.
I remember one of the Tmpgenc apps being quite good with using VRO files (which are the main movie files on those discs). Authoringworks, or its redecessor.
Of course, if that was used, it would just be trading DVD-RAM for DVD-Video. But that may be what you end up wanting.
Scott -
Neither of those helped, they just were all over the place in the timestamp.
Of course. Each recording from the DVD recorder starts with a new timestamp. What you want to do in Mpg2Cut2 is mark-in and mark-out each recording and Save This Clip to save each recording as an MPG file.
If the recordings are encrypted you need to decrypt them first with relCPRM. -
About 10 years ago, when I still had a DVD recorder that used DVD-RAM discs, I discovered that Cyberlink PowerProducer could import each individual recording from a disc containing multiple recordings. (The recordings were not encrypted.)
What I had then is now a very old version of the software and I don't know if the latest version still works the same way. However, Cyberlink offers a free trial for PowerProducer so it is possible to avoid spending any money to find out if it does.Ignore list: hello_hello, tried, TechLord, Snoopy329
Burning a DVD Disk to Bluray Disk
By tarzan54 in forum Authoring (Blu-ray)Replies: 9Last Post: 3rd Sep 2020, 20:27 -
Widescreen video not displayed properly
By sirblackjack in forum Authoring (DVD)Replies: 32Last Post: 30th Jun 2020, 12:04 -
Lenovo ThinkPad T440p i5 with 16GB RAM and 512GB SSD for video capture?
By VIDEO VOID in forum Capturing and VCRReplies: 4Last Post: 5th Nov 2019, 01:58 -
DVD extract video audio slideshow codecs
By SearchQuality in forum Video ConversionReplies: 5Last Post: 8th Aug 2017, 04:21 -
My video it is way too dark to see properly
By Wid01 in forum Newbie / General discussionsReplies: 14Last Post: 21st Feb 2017, 04:32
