I am trying to rip a dvd movie with DVDx 1.6 and MPEGEnc, everything goes fine until 10 sec later.. when I press start to encode with mpeg the movie begings but 5 to 10 seconds later DVDx gives me this error messege.
DVDx Error
MPEG2Dec: Too much sample
Try other frame rate or change Detect/Force 24 Hz flag
i did try to change the detect/force 24 Hz flag and it didnt work at all, I dont know what is another frame or how to chose it. if you know the solution to this please leave me a note here of email me. thanks.
I might doing something wrong with the installation of DVDx.
pazzi1@hotmail.com
That was a common problem with DVDx v1.6, upgrade to DVD v1.8a or any later version from 1.6, and it will work much better.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I've been trying to convert the SVCDs of LOTR using DVDx v1.8a and I get the "too much sample problem" also.
I think it has to do with an audio problem. If I disable audio/video sync (from the input settings window), then the whole thing encodes fine (I get an error about padding being needed, so I click yes). However, some of the audio is cut out and it's out of sync with the video.
Any ideas? -
What/Why are you trying to convert the SVCD's to ?
Best Regards,
Sefy Levy,
My DVD player can't play SVCDs. So I'm converting the files to VCDs. I think my player can play XVCDs, but I haven't done any of those conversion before and I wanna get these files off my HD. Plus I can get the movies on to three CDs instead of four CDs (less swaping).
BTW, I finally got the files converted and burned. I used DVD2AVI to get the D2V and MPA files. I then used TMPGEnc to get a final VCD file (surprised that it was perfectly sync'd) that I split and burned. Finally, no more "too much sample" errors.
Now if I could only get the MPEG off my Spiderman 1 CD without locking up my drive...
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 08:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 14:17 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
