So here is my ideal avisynth script. A filter analyzes an entire file, it finds 2:3 pulldown interlaced content, 30p content, and 60i content. It processes each differently. IVTC, passthrough, and QTGMC. And everything is brought together into a 60p file. Is this kind of script possible? Perhaps using a Conditional Filter? I've tried multiple ideas I've found online cobbling together multiple scripts here and there, with no luck whatsoever. Any assistance would be GREATLY appreciated.
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Results 1 to 17 of 17
lol good luck. once the various 2:3, 30p, 60i, content sources have been combined and re-encoded into one video they will all now say they are most likely 30p if that was the selected output. you can't go back to the previous source without actually owning it.
I'm not entirely sure what your last line is supposed to mean, but I think you're saying that source detection isn't possible. That's the entire purpose of this filter only accessible in MeGui.
http://avisynth.nl/index.php/Interlace_detection -
I'm disagreeing with it being true. Because it is not. Being mostly the same, and being the same are two entirely different things. Yes, most of the time it will be indistinguishable. But when you go through multiple movies worth of mixed source extras, or videotape sitcoms with 24p intros, you find out that this is not always the case.
Then you want to keep all the quality of the 24p and 30p parts by - I assume - duplicating frames, and only bob the interlaced sections.
He did say bobbing the entire thing with QTGMC wouldn't look 'much different', and he's right. I don't believe what you want is possible yet. I don't believe a filter has been developed to first run an analysis pass and then convert the entire thing to 59.94fps (IVTC what has to be IVTC'd followed by a ChangeFPS call to 60p, double the 30p to 60p, and bob with QTGMC the interlaced portions). You could do it manually, of course, but I guess you're looking for an automatic solution. Good luck. -
I haven't a clue. I'm with jagabo - just bob the whole thing and be done with it. Sorry, not much (any?) help.
It's okay, I understand your confusion. I've been doing just that for years, but lately I discovered bobbing progressive sources can wreak havoc on sharp edges, so I've been trying to figure out a way to process them separately, without having to stitch everything together by hand. As you can imagine, I'm at a loss.
Try using interleaved TFMs with no post processing to bob, then use ConditionalFilter with IsCombedTIVTC to select:
Code:function TFMBob(clip v, int "pp") { pp = default(pp, 6) v.GetParity() ? Interleave(TFM(v, field=1, pp=pp), TFM(v, field=0, pp=pp)) : Interleave(TFM(v, field=0, pp=pp), TFM(v, field=1, pp=pp)) } LWlibavVideoSource("video.avi") t = TFMBob(0) q = QTGMC() ConditionalFilter(t, q, t, "IsCombedTIVTC")
I really appreciate your help, but unfortunately I don't think this is going to work. I'm getting too many missed frames where not much is moving. I've tried adjusting every setting in TFM I can find to adjust the combing detection parameters but nothing is working. Sure, I could just let it go, but if I was the type to do that, I wouldn't be here in the first place. I'm not really sure if this means combining everything by hand, or just letting QTGMC do it's thing. I guess I'll figure that out soon.
Here is my current iteration of the script, in case you have anymore ideas.
Code:Footage = AVISource("G:\Deinterlace\test.avi") function TFMBob(clip v, int "pp") { pp = default(pp, 6) slow = 2 mode = 5 cthresh = 0 MI = 0 blockx = 256 blocky = 256 metric = 1 v.GetParity() ? Interleave(TFM(v, mode=mode, cthresh=cthresh, pp=pp, slow=slow, MI=MI, blockx=blockx, blocky=blocky, metric = metric, field=1), TFM(v, mode=mode, cthresh=cthresh, pp=pp, slow=slow, MI=MI, blockx=blockx, blocky=blocky, metric = metric, field=1)) : Interleave(TFM(v, mode=mode, cthresh=cthresh, pp=pp, slow=slow, MI=MI, blockx=blockx, blocky=blocky, metric = metric, field=0), TFM(v, mode=mode, cthresh=cthresh, pp=pp, slow=slow, MI=MI, blockx=blockx, blocky=blocky, metric = metric, field=0)) } t = Footage.TFMBob(1) q = Footage.AssumeTFF.QTGMC(Preset="Slower", EdiThreads=4, NoiseProcess=0, Sharpness=0, SourceMatch=3, Lossless=2) ConditionalFilter(t, q, t, "IsCombedTIVTC", "=", "true")
https://drive.google.com/file/d/1ManuJsMgvTQnQzcbLIYUXPTptdGml06P/
I've had more luck using those settings in IsCombedTIVTC. Right now it's just a balancing act, so there aren't too many frames being detected as combed (the IVTC portions), and not enough. -
There are a few mistakes in your script in post #14. You forgot to AssumeTFF() to the clip that's sent to TFMBob(). Within TFMBob() some of the four calls to TFM() have the wrong field value. You have the order 1, 1, 0, 0. They should be 1, 0, 0, 1, as in my original example. Those are causing the TFMBob() to bob the film sections with a 2:2:2:4 pattern rather than 2:3:2:3, making motion more jerky. I noticed that my original example called TFMBob(0) rather than TFMBob(1) -- which you fixed.
As is common with introductory sequences, the clip does have some shots that were sped up or slowed down. For example, the "biking down Lombard Street" shot starting around 1:07. There are many orphaned fields. That is causing aliasing on some frames after processing. A straight QTGMC() of that shot looks better.
Help writing a script for manual IVTC
By Fraugster in forum EditingReplies: 22Last Post: 30th Aug 2019, 21:22 -
60i to 60i output with Avisynth?
By ENunn in forum Video ConversionReplies: 36Last Post: 17th Aug 2019, 20:59 -
QTGMC and TDecimate as a custom IVTC script?
By Vitality in forum RestorationReplies: 9Last Post: 22nd Nov 2018, 17:04 -
Which is better: 60i deinterlaced or 30p?
By SameSelf in forum Video ConversionReplies: 8Last Post: 30th Jun 2016, 13:31 -
FFMPEG convert 60p to 60i
By nesburf in forum Video ConversionReplies: 7Last Post: 27th Feb 2016, 16:32
