Hi!
First post - first question: I want to record my daughter playing piano and the sound quality could be better. So I wanted to connect my microphone to the Canon HF100 camcorder in order to improve that. However, the camcorder doesnt record any sounds then. I have tried two external microphones so far:
Sennheiser e935
Rode NT1-A
They are usually made to record singing and they are then connected to a mixer.
I bought myself an XLR female to mini-cinch cable to connect the microphone to the camcorder.
Where is my error? Any help would be greatly appreciated.
Alex
Yes i checked that. The Rode could need that. However the Sennheiser should work without phantom power...
johnmeyer is right.
the hf100 can only use self powered external mics or the canon shoe attachment mic. xlr type mics aren't going to work.--
does the sennheiser have it's own battery? i don't think so, but i've been wrong before.
The Rode does need phantom power. Be mindful of what kind of connection is expected - balanced/unbalanced, mono/stereo, input/output/io, as the pinouts on cams use them in a variety of ways. That's why there is diff between ts/trs/trrs.
Note: nature of phantom power REQUIRES balanced input. So if you are adapting bal->unbal it won't work for true condensers.
Suggestion: optimal postioning for cam is often NOT optimal positioning for mic. Keep them separate. In fact, just do double system (use a zoom h2/h4n or something) and marry them in post.
No Audio Recorded Using External Mic With Canon Vixia XA-11
By D.V. Dee in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 24th Dec 2020, 14:17 -
MP4Box as external muxer in Virtualdub doesn't produce a file
By wout25 in forum Newbie / General discussionsReplies: 12Last Post: 14th Oct 2020, 13:14 -
Nero doesn't link with external device
By BabyDaddy in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2020, 07:51 -
external microphone to android connection problem
By Kasidokostas in forum AudioReplies: 25Last Post: 3rd Mar 2020, 16:44 -
Canon Legria HF G40 with Canon SM-V1 Surround Microphone Problem
By dpaterson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 8th May 2018, 13:03
