I got my Sony DCR-HC35E back up running again since I had it stored away for almost 10 years I guess. I charged it and everything seemed good till I tried to set the date. At first I did some troubleshooting but I came to the conclusion that it must be a software error.
I’m pretty sure about that because while calibrating the touchscreen it works just fine like normal. But after going into operating mode I need to set the date which is impossible without the touchscreen working. Anybody out there that experienced something similar and fix the problem. If you can help my out in anyway just get back to.
Thanks in advance.
can't help. had the same problem with mine and ended up tossing it in the trash. i won't be buying any sony products in the future.
Sony DCR-HC30 Touchscreen not working
By Subhash in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 26th Jul 2023, 15:23 -
Capture quality from Sony DCR-PC100E ?.
By iosman in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2021, 15:50 -
Sony DCR-TRV480
By Frederickgolf in forum MacReplies: 12Last Post: 26th Sep 2020, 12:32 -
Sony DCR-PC10 Capture
By tarnished88 in forum Capturing and VCRReplies: 24Last Post: 4th Aug 2019, 01:23 -
Sony DCR-TRV8E - DV. How do I digitise to a Mac?
By cosmos65 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2018, 20:07
