Haven't used any video editing software in years so forgive what is probably a very stupid problem ! Just starting to use VSDC editor , but can't seem to create the final disk.
I imported some old videos , created project and edited/reviewed. Then Exported project in DVD format. Finally used Disk Burner to create DVD I hoped to use on my player.
Burn process ran seemingly fine and gave message that Burning had completed successfully and drive opened. I closed drive and opened Windows Explorer expecting to find .vob files etc on disk. Instead all I see is a message saying 'Files ready to be writtento Disk (1)'. Tried right click in empty area ans selected Burn to Disk but got message 'No files staged to burn. Please add the files that you want to burn to this disk then try burning again' ? (Windows Temporary Burn Folder is empty btw).
Can anyone please tell me what I've done wrong ?? Thanks
Thanks for tip. This has at least pointed at the real problem ! Using Imgburn and a copy of my exported file on my wife's laptop all worked fine. On mine Imgburn errors with 'Verify failed. Reason - Layouts do not match'. Also try a simple cut/paste to the drive that failed. So issue is either hardware or driver related - and not a problem with VSDC. Interestingly VSDC says evrything worked fine - just no file(s) created on disk. Tried deleting device and rebooting, but same problem - so driver probably OK. Left with a hardware fault I guess..........
Burning a DVD Disk to Bluray Disk
By tarzan54 in forum Authoring (Blu-ray)Replies: 9Last Post: 3rd Sep 2020, 20:27 -
Problem burning a DVD
By dibby39 in forum Newbie / General discussionsReplies: 11Last Post: 9th Apr 2018, 08:01 -
Problem burning DVD Please Help
By COOLKEV in forum DVD RippingReplies: 6Last Post: 28th Feb 2018, 09:50 -
Problem ripping DVD titles to mp4 format for iPhone 6S Plus
By ianpwilliams in forum DVD RippingReplies: 1Last Post: 30th Aug 2016, 14:53 -
Burning 720p files to a blu ray disk to watch in HD
By Gil T Remnant in forum Authoring (Blu-ray)Replies: 6Last Post: 10th Apr 2016, 17:12
