I have a IDX file that contains the following:
When I play the video with MPC-HC with the subtitle as an external file, the placement is exactly as I want it. However, when I mux the subtitle in the video (MKVMerge), the offset is ignored and the subtitle is placed at (0,0). If I demux the subtitle I can confirm that the IDX file was not edited. I could not find any option with MKVMerge that would pertain to this behavior, so what gives?Code:size: 720x576 org: 110, 0 scale: 70%, 100%
Unfortunately I have to make this work, the video is anamorphic 16:9 and without the downscaling the text is stretched very unpleasantly. I'd rather not have to OCR the subtitle either as this process requires a lot of proof-reading...
MAYBE the problem is in LAV Splitter or/and in the Internal Subtitle Renderer of MPC-HC...
does the problem still happen if/when you use VSFilter
P.S.: Also,
Have you set the correct aspect ratio in MKVmerge's GUIthe video is anamorphic 16:9
OR configured LAV Splitter /Video_Decoder "properly"
"Programmers are human-shaped machines that transform alcohol into bugs." -
How to change audio offset step by 1 instead of 25 on Kodi?
By Runakanta in forum Newbie / General discussionsReplies: 7Last Post: 30th Dec 2022, 08:18 -
offset blu ray sup?
By chisdchisdq in forum SubtitleReplies: 4Last Post: 17th Jun 2020, 21:22 -
how can i offset the frames on the chroma channel in avisynth
By flashlight in forum RestorationReplies: 11Last Post: 5th Mar 2018, 19:15 -
Offset and length were out of bounds...
By rudolfp in forum Video ConversionReplies: 0Last Post: 20th Dec 2017, 02:56 -
Avidemux muxed-mkv displays 720x576, Toolnix muxed-mkv 787x576
By jfjfjf in forum Newbie / General discussionsReplies: 5Last Post: 18th Nov 2017, 11:43
