    Aug 2015
    Quebec, Canada
    Is there an easy way to convert CC EIA-608 into simple .stc ? my file is in .mp4
    I've tried CCExtractorGUI and FFMPEG with no luck
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    CCExtractor should work with the correct parameters set. Another workaround, you could try would be to wrap the mp4 in a MKV container using MKVToolNix and this should show the audio video and sub, you can then extract just the sub with MKVCleaver
    Aug 2006
    Another method: https://forum.videohelp.com/threads/341312-How-to-extract-Close-Captions-(EIA-608)-fro...ts#post2125410
    Below is the text for a batch file to process mp4 files with eac3to to demux all streams, with the EIA-608 closed captions extracted as srt files. To create the batch file, paste the text into Notepad and save with the extension .bat
    for %%a in ("*.mp4") do eac3to %%a -demux
    pause
    Aug 2015
    Quebec, Canada
    usually_quiet
    I'm trying your method using :
    for %%a in ("01v1.mp4") do eac3to %%a -demux
    pause
    The format of the source file could not be detected. message
    the .mp4 is working fine on all players (VCL and others), I'm not sure why It can't be read
    Jul 2011
    Denmark
    Perhaps GPAC MP4Box or Subtitle Edit?
    Aug 2015
    Quebec, Canada
    MP4Box & Subtitle Edit can't detect this EIA-608 CC.
    what parameters can work in CCExtractor ? I've tried many combo with success.
