Hi.
I read that hvec(x265) codec can give the same quality
video compare to avc(x264)codec,while using 40%-50% less
bitrate for second(smaller file size).
So,if i would like to convert a video file with x265 codec to x264 codec
and i would like to save the quality(or minimize the loss),should i double the bitrate/sec while i make the conversion to x264?
Thanks.
	For a good x264 quality encode with CRF range 18-21. The bitrate is determined by the encoder.
	Thanks,ProWo.
 Yes,i am familiar with the CRF option,
 But what if the software doesn't have the CRF parameter option?
 and there is only the option to choose bitrate/sec value,
 should i double the bitrate value?maybe triple it?when i convert x265
 to x264?
  Encode x264 to x265?By BlurayHD in forum Video ConversionReplies: 7Last Post: 7th Jan 2019, 09:30
  x264 and x265 - DifferenceBy THRobinson in forum Video ConversionReplies: 60Last Post: 9th Nov 2016, 14:43
  Transcoding x265 to x264By therock003 in forum Video ConversionReplies: 3Last Post: 27th Oct 2016, 02:19
  moving from x264 to x265By ben45 in forum Video ConversionReplies: 4Last Post: 16th Aug 2016, 17:26
  Simple x264/x265 Launcher help!!!!By Hiacios in forum Video ConversionReplies: 7Last Post: 14th Jun 2016, 10:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
