I'm sure this is basic but I'm definitely new to video. I understand the difference between variable and constant. I read where the iPhone records VFR and would like to know how
important is it to convert to CFR.? I use Filmic pro and Hitfilm to edit,
Thank you,,
The best answer is to experiment. Try them and see if they give you much grief.
If you have Filmic Pro on your phone you can shoot CFR from the beginning -- that was part of why it was invented. (I know less about Hitfilm.)
VFR to CFR conversion before editing
By droner in forum EditingReplies: 42Last Post: 15th Feb 2021, 05:01 -
VFR to CFR and Audio Sync
By videohelpuser in forum Video ConversionReplies: 3Last Post: 23rd Dec 2019, 11:46 -
I want to convert VFR to CFR while keeping the video interlaced
By ENunn in forum Video ConversionReplies: 34Last Post: 24th Apr 2019, 05:50 -
Turning video from VFR to CFR without re-encoding?
By yetanotherlogin in forum EditingReplies: 3Last Post: 29th Aug 2016, 11:09 -
VFR to CFR
By SameSelf in forum Video ConversionReplies: 6Last Post: 7th Jun 2016, 20:46
