The VirtualDub descriptions by Fishman on GitHub use formatting I'm not familiar with. The capture description is at https://github.com/fishman/virtualdub/blob/master/helpfile/source/capture.lina. Any idea what word processing program can handle the formatting commands? The formatting looks similar to what I used to use on a VAX system in the early 1980s.
Thanks,
Steve
BTW: I attached a text file with the VirtualDub description information from GitHub
Yep, that was the right answer. I didn't recognize it as HTML since I've never done HTML formatting.
Thanks for the help,
Steve -
Actually, there's more to the story. The source files on GitHub contain statements such as the following that creates files, tables, and pictures from other folders and files on the GitHub site.
<lina:create file="p-pipeline.html" title="Processing: The pipeline">
<h1>Processing: The pipeline</h1>
<style>
table.pipeline {
table.pipeline th {
background: #8ae;
table.pipeline td {
background: #aea;
</style>
and
<blockquote>
<lina:image src="pics/c-spilldrives.png"/>
</blockquote>
Any idea what will process all of the commands and create the final document from the multiple source files?
Thanks,
Steve -
Old thread but I happened upon it.
A Google search for "site:virtualdub.org lina" revealed the answer: http://www.virtualdub.org/blog2/entry_066.html
Lina is the interpreter for these files, it was also written by VirtualDub's author, and the source code for it is in the "Lina" directory.
Or just open Help from within VirtualDub to see it with the intended formatting. Don't know what prompted the original question.My YouTube channel with little clips: vhs-decode, comparing TBC, etc.
When changing color to a word, the word jumps over to other place in captio
By sarit1 in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2020, 14:04 -
How to install and use all the GitHub's TypesettingTools
By ShaniRBD in forum Newbie / General discussionsReplies: 0Last Post: 14th Jan 2020, 12:45 -
Vl sub is not responding error. Github latest download of lua did not solve
By jraju in forum Newbie / General discussionsReplies: 0Last Post: 2nd Dec 2019, 04:41 -
how to find dll files in github
By Betelman in forum RestorationReplies: 1Last Post: 3rd Jun 2019, 20:02 -
using virtualdub to batch process deshaking, saving using h264 codec
By seanincali in forum EditingReplies: 7Last Post: 31st Mar 2017, 11:38
