Hi
I am having trouble getting started with digitizing my VHS.
The issue is my VHS player, I believe, because it doesn't have a Composite OUT and instead only has the three colors (Yellow, Red, White) with IN connection written on it.
So, my question is can anyone in this knowledgeable community recommend me some VHS players which have the Composite OUT and also S-Video ports, as my current VHS player doesn't have the S-Video port too?
Also, I live in the United Kingdom, so does the VHS player have to be a PAL only device or does it not matter if it also was NTSC?
Thank You!
Results 1 to 13 of 13
I’ve connected the SCART to Composite adapter and moved the switch to OUT, but the CE310B is not showing up on either AVerMedia’s Capture Studio & even on VirtualDub which says the following “VirtualDub cannot connect to the desired capture card”.
I’m at loss as to what to do.
I think as a last resort might give the VHS digitisation services a go.
I’ve also got the latest driver installed for the CE310B.
Any help is appreciated! -
Open device manager (search in start menu) and you’ll see a long list of devices. Usually if a device has issues or lacks a driver, its line will be open/expanded.
If everything looks ok, see if you can actually find it at all, in the list. It may have a generic name so use your imagination if you can’t find anything with avermedia in it.
In any case, download the latest drivers from the avermedia website.
You should also check if the card is properly inserted in the slot. -
Yep, have seated the CE310B properly and there were no warning signs or anything in Device Manager, also it didn’t have a generic name, instead it said “AVerMedia CE310B Capture Device” or “Card”.
So, it recognises the card in Device Manager, but not in AVerMedia’s capture programme or VirtualDub for example.
I’m not sure what to do with this capture card anymore. It’s annoying. -
Try OSB and maybe it’ll detect it.
Its not a good sign if the card isn’t detected by its own software....
Try something out of the ordinary like removing and reinstalling it, if possible in another slot. -
Have you solved your issue?
I run into the same issue today. Haven't used the card since three or four years and now it is not even recognized in their own Avermedia Capture Studio. Device Manager says everything fine, I tried different drivers including the latest one, tried a different PCIe slot, but the card is only shown in the Device Manager. -
Look in Windpws 10 settings at Privacy, particularly the app permissions related to camera, microphone,etc.
[AVerMedia News] Avermedia RECentral HDCP Protect Remove!!!
By Cauptain in forum Capturing and VCRReplies: 234Last Post: 31st Dec 2025, 19:15 -
AverMedia CE310B PCIe card - how do I get it to stop (badly)de-interlacing?
By bergqvistjl in forum Capturing and VCRReplies: 3Last Post: 30th Mar 2022, 23:17 -
Built-in VHS player in CRTs, image quality vs external player?
By xAlienxx in forum MediaReplies: 4Last Post: 7th Mar 2019, 18:57 -
Anyone have experience with AverMedia PCIe CE310B capture card?
By Bassquake in forum Capturing and VCRReplies: 4Last Post: 27th Jul 2018, 23:08 -
using the AverMedia ER310 to capture VHS
By jwillis84 in forum Capturing and VCRReplies: 0Last Post: 2nd Jul 2018, 16:50
