No wonder. The new .mkv file is a conflict in itself: Tweaking the level to 4.1 but leaving the framerate at 50fps. The maximum framerate for level 4.1 is 30fps for 1920x1080 resolution.
One can usually not make wine from vinegar (or vice versa) by just exchanging the label of the bottle. One can always try, of course![]()
Results 31 to 48 of 48
The newer tvs can play 1920x1080 at 50/60 fps as i mentioned but the older one are limited to 30fps.
And note that the sample you posted has 50 frames per second but every pair of frames is identical. So you're not losing any motion smoothness by reducing the frame rate to 25 fps. If it had been live sports (which truly has 50 different frames every second) you would noticed a drop in smoothness after converting to 25 fps.
I have the exact same problem with a Panasonic TV. The media players in these things are not very advanced and very specific. When I hit a file that won't play, I use VLC to convert it. Tedious and lengthy process but it works. The VLC profile H.264 +mp3(mp4) is basic enough to play on anything in my experience.
I've advanced a lot since I started this thread. The best so far is to download a copy of Handbrake from this site and convert any videos that can't be played by your standard dumb-normal TV media player. Handbrake has lots of presets but it seems to me thaat anything MP4 or MKV in an X.264 container will work. Also, it's a good idea to convert the audio to stereo.
Just wanna add that for the videos that won't play, your idea of using FF.mpeg to convert them into a more compatible format is a good approach. You might want to consider transcoding the videos to a format that's known to work well with your TV, like H.264 in an MP4 container. Make sure to adjust the codec parameters and container settings accordingly.
As for the audio and video combination, ensure that you're using compatible audio and video codecs within the same container format. Using FFmpeg, you can try commands like: ffmpeg -i input_video.mp4 -i input_audio.m4a -c:v copy -c:a copy output_combined.mp4.
By the way, Multitechverse might have some valuable insights or tools related to multimedia technology that could help you with your video conversion endeavors.Last edited by msdevelish; 30th Aug 2023 at 08:20.
But of course if it's an old TV you are stuck with conversions. Get yo ass off to costco and upgrade the TV
Or buy a media player. Even US$20 devices can play 4K with h.264, h.265, vp8, vp9...
https://www.walmart.com/ip/onn-Google-TV-4K-Streaming-Box-New-2023-4K-UHD-resolution/2835618394
About the only thing that's missing in the cheapest devices is the AV1 codec.
mp4 not playing sound on Samsung TV
By Frederickgolf in forum MacReplies: 10Last Post: 6th Sep 2020, 19:38 -
Samsung TV playing video with 7.1 audio
By Video0001 in forum DVB / IPTVReplies: 13Last Post: 5th Dec 2017, 17:43 -
Samsung writer won't reinstall, not supported by Samsung
By blacktooth in forum DVD & Blu-ray WritersReplies: 4Last Post: 11th Jan 2017, 23:47 -
MKV movies has STOPPED playing on Samsung Smart TV
By WindChilln in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2016, 10:19 -
Region code needed for Samsung
By martinalison in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2016, 20:35
